I visited Roger just before Easter and collected my 200w panel kit. My brother helped me fit them which took just over an hour. Unfortunately I was given the kit for a Ocean, and one of the leads was a little short. I made a minor detour on my way from Somerset to Devon and an apologetic Roger gave me the correct length lead.Anybody any experience of using solar panels with their Cali, in particular the Solar Camper Solutions unit??
Yep, have emailed Roger. Do you know what warranty he provides ?Hi @BerndRos - you had yours installed just before our, I think, so it's only about 14 months.
Have you contacted Roger Donoghue and asked him what it could be?
He's been very helpful when I've contacted him over any issues. Simon
Hi, l have a similar issue. The MPPT shows 14v but I cannot get more than max 1.5 A. Tried everything. Checked cabling and connections, reset the MPPT. Tried with full and low battery and different amounts of sun. The result is that my fridge is draining the battery and the solar panel has no effect. I used to get at least 3.5A. Unsure whether to buy a new panel or MPPT?My 'ROGER' kit is playing up. About 4 weeks ago the MPPT started showing only 9volts and no amps from the PV in direct strong sun.
Have cleaned the panel and checked all contacts, then used a multi meter to test at the panel, still only 9volts.
Any ideas please ?
First, with a multi meter test the voltage at the join in the cabling on the roof, or further back inside the junction box on the solar panel. If that reads the same as on your MPPT, then it's the panel rather than the MPPT, I think.Hi, l have a similar issue. The MPPT shows 14v but I cannot get more than max 1.5 A. Tried everything. Checked cabling and connections, reset the MPPT. Tried with full and low battery and different amounts of sun. The result is that my fridge is draining the battery and the solar panel has no effect. I used to get at least 3.5A. Unsure whether to buy a new panel or MPPT?
I will let it run a little while longer and reassess later as it seems have taken a new direction.Mods - can we collapse / wind into another thread pls?
Nope, perhaps send again...thanks RogerHi Kevn, I replied earlier. Is it in your spam folder?
Hi, I’m having a similar problem with my Roger installation. What was the solution in the end?Hi, l have a similar issue. The MPPT shows 14v but I cannot get more than max 1.5 A. Tried everything. Checked cabling and connections, reset the MPPT. Tried with full and low battery and different amounts of sun. The result is that my fridge is draining the battery and the solar panel has no effect. I used to get at least 3.5A. Unsure whether to buy a new panel or MPPT?
Hi, what was the solution? My Roger installation is playing up!My 'ROGER' kit is playing up. About 4 weeks ago the MPPT started showing only 9volts and no amps from the PV in direct strong sun.
Any ideas please ?
My experience with MPPT is that if your battery is full or close to full it will ramp down. Does the amps go up if you put a load on your battery?Hi, I’m having a similar problem with my Roger installation. What was the solution in the end?
