Niborn
I was just wondering , given the weight of the Cali , if it was easy to change a wheel with the jack supplied ? Any experience of this would be appreciated - many thanks
It is adequate for the purpose, even on a fully loaded vehicle. It would be a legal nightmare if VW supplied something like this that wasn't.I was just wondering , given the weight of the Cali , if it was easy to change a wheel with the jack supplied ? Any experience of this would be appreciated - many thanks
Nobody has mentioned removing the spare wheel from its carrier and even more so replacing it in the carrier. It is a difficult job to get the wheel back on the carrier plate even on a good flat, solid and even surface, it would be almost impossible on a rough uneven surface.
If you have the space inside the vehicle the 'flat' can always be carried there temporarily BUT be aware that if you put a wheel & tyre down on the van floor it is likely to stain the floor from the compound of the rubber. I dumped mine in the back on an upturned mat just in case and it left a permanent black ring on the back of the mat!
Rod
Just back the van onto your levelling blocks. Makes removing/replacing the spare in the cradle easier.
Now HC I had you down as a clever bloke. I wasn't suggesting jack it when it's on the blo........oh whatever.Agree , but i am not jacking up a Cali when it is on leveling blocks , why put it on levelingblocks when the next step is jacking up? Leave the blocks in the Cali .
Seeing an AA man with a van full of tools struggling to change the tire convinced me to never want to have to do it!! biggest problem is as everyone has said getting the spare back in the cradle.
Not so. At full droop (tyre clear of the ground) there is plenty of camber induced. As you lower the van the camber applies side load.Not tried it - not much side loading so I'm not convinced the spigot wont just take the load but will bear in mind for next time. Thanks
Pleased that you got it sorted. At least it wasn't raining.But got very dirty. Might be worth carrying some gloves somewhere.
