Paulro
I bought the kit off Roger Donahue a year ago. I think it has worked for about a day only.
All of the rest of the time it shows no charge being given to the battery.
Today I took it to Taunton where Roger looked at it, tested of the component parts, the panel, the charger, the connections etc.
So, the solar panel is producing charge and when connected to a remote battery which was not fully charged continued to charge to normal values.
The charger worked well with the remote battery.
All connections on my California leisure battery and fuse were checked. All ok.
But the charger would not charge because it was reading the rear leisure battery as fully charged although the control panel shows 90% and 12.3v.
Roger said that the two batteries do not seem to be connected?
I have no idea about electrics and will most likely need an auto electrician but someone here might be able to shed some light on this.
The batteries should have been well charged as they had been on charge for around 24 hours but this issue of the leisure batteries not being connected?
Is this possible?
Is there some sort of breaker between the two batteries that might account for this?
Help.....
Is this possible?
Help.....
