motacyclist
Colin
Rear AirCon Heat Exchanger drainage. Switching on Rear AirCon only switches on the fans and adjusts the airflow temperature at the rear. Refrigerant still flows around the circuit as long as the AC is On.Noticed this today, I’m hoping it’s just condensate from the a/c but it seems a strange location. It was coming out from behind the plastic wheel arch liner. Appeared to be colourless and odourless. I didn’t have the rear a/c turned on. Hadn’t driven through any water.
Has anyone else had this?
Thats what i think it is on mine.Rear AirCon Heat Exchanger drainage.
Thanks Paul, is there an other drain up front somewhere? There was no other water on the path ....Rear AirCon Heat Exchanger drainage.
This is on the opposite side to the water tank, and haven’t put any water in for about 10 days, so I don’t think it’s that ....Had you topped up your water recently?
We had the same last week I had filled up the water tank until it overflowed. Drove down to the sea about 6 miles away and later found the same so put it down to top up water running around the inside of the bumper - never seen it before and surprised it seemed to take quite a while and distance to run out.
I must admit I did check the PortaPotti wasn't leaking! (Volks Pee?)dog or cat pee?![]()
I don't think it's that, we've had no rain recently and the van had done an 80 mile drive so I think that would have been dry. Still a possibility I suppose ....roof channel drain?
Looks like a/c drain is favourite, but I would have expected to see one for the front a/c too ...I get the same. No water tanks and the rear drain comes out behind the tailgate. Never been able to locate the source but the rear air on makes sense as I run with A/C on all the time.
I get it at the front also, leave the van running with the aircon onLooks like a/c drain is favourite, but I would have expected to see one for the front a/c too ...
There is a front drain, central engine bay, but tends to drain much better when driving compared to rear.Thanks Paul, is there an other drain up front somewhere? There was no other water on the path ....
