What is this (not the usual suspect!)
motacyclist
motacyclist
Colin
Chester
Cali now sold
Found this on the floor by the sliding door, made of rubber, about 25 x 60mm. It may not be off the van, but the sound the door makes as it comes to a stop when opening sounds a bit different ....
Found this on the flood by the sliding door, made of rubber, about 25 x 60mm. It may not be off the van, but the sound the door makes as it comes to a stop when opening sounds a bit different ....
I don’t recognize it is there a part number on it ? It would start with something like 7h0 or 7E7
No, I think that probably means it hasn’t fallen off the van! I knew we shouldn’t have taken the bondage gear on that last trip! :D;)
You raise a valid issue, this is probably a side issue, but it’s been worrying me for a while, do you think VW has built in enough shackle points?
