motacyclist
Colin
Is the California a (very) mild hybrid?
On a drive out today up the North Wales coast, after about half a mile I checked the MFD out of interest and the batteries were taking >20 amps on the display. A short time later, it was showing minus 14 - 15 amps discharge, and this continued for the rest of the journey, apart from a downhill stretch when I tapped the brake to disable coasting and the display then showed >20 amps charge again.
When we stopped after about 40 miles, the leisure batteries were on 70% and 12.3 volts. So the technology appeared to have been using the leisure batteries to power the ancillaries and thus presumably save fuel? (Not much use if you arrive on site for a few days off grid with only 70% though!)
Coming back, the situation changed and the battery constantly received a fairly steady charge of 4 - 5 amps, rising to around 17 amps on braking/decelerating. Arriving home, the batteries showed 100% and over 13 volts.
There was a small change in fuel consumption each direction, going out we got 39mpg, coming back it dropped to 38.5mpg overall. Wind was coming from the side, so shouldn’t have had much effect.
I wonder if anyone else has noticed this, or has any opinions on the assumption that the fuel saving algorithm is making use of the leisure batteries? I seem to remember reading a thread somewhere that it does, or maybe I was dreaming .....
