Kenwood DNX518VDABS
Pro moochers
Pro moochers
widnes
T5 SE 140
I’ve just been speaking to a company about upgrading my VW head unit.
I’m not keen on the look of the generic square units and wanted something with a factory look, and functional buttons.
They recommended the Kenwood DNX518VDABS which looks perfect, but my god it’s expensive!!
Quoted £1195 plus installation.
Is there a recommended alternative with similar looks?
Key things I want are Apple car play, Bluetooth audio and DAB.
Cheers
I had this installed last year:
Kenwood DNX 5180dabs
>> flush fit facia
>> Kenwood dab aerial
>> Kenwood interface for parking sensors,mfsw fm adapter
>> £915.00 plus £45.00 for installation.
Works a treat and much better than my old VW head unit which I found to be very restrictive when on my own in the van, in terms of difficulty selecting music etc. DAB is very handy too.
Cheers
Checkout Absolut5. Very approachable. Specialists for the T5/6. Well recommended and can supply a DIY kit that is plug and play or fit themselves. Worth a call. There are other models/makes.
He is also a Forum Member.
You could PM him if you were a VIP member.
That's who did mine :thumb.
I’m all for using recommenced companies but they’re miles away from home and I’m about as technical as a pint of milk
We recommend the Kenwood DNX 8180dab or 9190dab over the DNX518dab all day long as they have motorised reverse tilt screens to deal with sun glare, the 518 is affected terribly
We can supply it as a plug and play
Whoops... booked mine in for the 518 today
Let’s just hope we don’t get much sun
Hows the 518 going Zesty? Just ordered one!! £840 plus vat fitted... Any sun issues etc etc...
Got Blam 20 inch front speakers/tweeters already fitted but RNS510 is holding them back!
Will they maintain all the existing display functions.. climate/proximity/seats etc that displays on my RNS510 in my T5.1?
So far so good!
Haven’t driven in bright sun yet
£1199.00 inv and £1429.00 the 9190 also has wireless CarPlay, both have vastly better screens than the 518, but can supply and install the 518 if you like
Sorry Absolut5.. Long way away and I have a local fitter who is pencilled in now. Sorry
>> flush fit facia
>> Kenwood dab aerial
Hi, I’ve just had my unit upgraded to the KENWOOD DNX518VDABS system by my local VW van centre. Really pleased with it so far. However the system does not power up without the key being in the ignition and turned to stage 1. Is this something that can be rectified?
That's the way it works unfortunately. It also probably turns off after 20 mins or so. Nothing to do with the installation, it's the same as the standard stereo worked.
It can be worked around but needs an Auto Electrician I think.
Not quite. I can turn my RNS510 on without using the key, by just pressing the On/Off button. It does switch off after about 20+ minutes.
Hmm, must have forgotten that did it!
Are people really that impressed with the sound from their kenwood? I fitted a 525dnx last year, I know it's an older model but same make, and cannot get it to sound anywhere near as good as the original vw. Am I missing something with the kenwood sound? I'm prepared to try something newer or different to get a better sound.
Have you changed the speakers? They are often the weak link.
There were big changes to the Kenwood line up after that model, with massive improvements.
Also as another poster said, the original speakers were designed to be run off the original head unit so we’re matched.
When are we going to get aftermarket head units from Kenwood, Pioneer, Alpine etc (I know you can get them from lesser known sources) that have iPad standard screens and software? They all look pretty naff to me in comparison, and using a smartphone/ tablet as much as I do, I can’t help but compare!
When I looked at pioneer units, when at the show, I'm sure you could mirror your phone onto the screen.
Have you looked at Apple CarPlay?
I’ve got it on my Pioneer unit fitted last year by Absolut5. I do like and use CarPlay, but it uses Pioneer’s screen - which is a long way off the quality of an iPad screen. That‘s my main moan really, though the graphics etc of the Pioneer unit, as with those from other mainstream manufacturers, just seems, as I say, naff. Should we really have to suffer with being unable to see screens when the sun is shining for instance? No problem with an iPad. I guess I’m just wondering why I can‘t have an iPad-like user experience on a vehicle aftermarket headunit - even the crazy expensive ones, where the best we can hope for is an expensive mechanical tilt in an attempt to avoid the sun (I have v limited experience of current vehicle manufacturer headunits, VW for instance, but from what I’ve seen, they seem to have improved a lot since we bought our Cali new in 2010)
Sorry about the constant iPad references, I’m sure there are other decent tablets :)
