That’s a good point. Anyone with a wind out knows you need to dip one side when it rains. That will properly screw up your feng shui with the awning side wall thingy attached.Good evening,
I haven't use the awning an awful lot yet. The weather was simply not warm and sunny enough.
But that is my question (if it is ok to raise it here), do you use the awning as protection against rain or only as a sun shade? In other words is the awning designed to protect against rain?
Of course it is clear that if it is used as a rain shelter that it has to be fixed properly.
Regards,
Eberhard
Awning is a protection against anything, as long as it’s not so fierce it causes damage.Good evening,
Regards,
Eberhard
What I want to look into, is a tarp to come off the passenger side rail at about 45degrees-ish to ground, where I can throw a few things under at night. Something that just keeps the rain and elements off the chairs and stuff, to save packing away.
Cali kev had one at the slimbridge meet. Might be worth asking him where he got it. I'm sure there's a video knocking about somewhereWhat I want to look into, is a tarp to come off the passenger side rail at about 45degrees-ish to ground, where I can throw a few things under at night. Something that just keeps the rain and elements off the chairs and stuff, to save packing away.
Would be easy to set up. If you sewed awning piping to it it would be easy to attach to an awning rail or you could use hooks and tie it. Good quality dark shower curtains can be used as side panels. A tarp is great as you have many configurations, especially if you have some tentpoles with you too. Used one (sometimes two) loads with our old Toyota. At Easter I trialed a tailgate rain protector with a tarp folded in half but didn’t take a picture.What I want to look into, is a tarp to come off the passenger side rail at about 45degrees-ish to ground, where I can throw a few things under at night. Something that just keeps the rain and elements off the chairs and stuff, to save packing away.
Quechua do a good nylon (tent material) tarp for around £25 which comes with some poles. The Bushcraft store also stock different types and qualities.Cali kev had one at the slimbridge meet. Might be worth asking him where he got it. I'm sure there's a video knocking about somewhere
Simple to do. 2 Awning Thumb Screws. 2.5 meter wide awning tied to the Screws and then either use Guy Lines to the ground or some cheap poles and guys to maintain some height.What I want to look into, is a tarp to come off the passenger side rail at about 45degrees-ish to ground, where I can throw a few things under at night. Something that just keeps the rain and elements off the chairs and stuff, to save packing away.
Depends what type of trip you’re on, how long for and what kit you take as to whether an awning is a good idea or not.I currently use a base seconds. Which is ok. But we only use it to store a Toddlers car seat, buggy and the chairs and table.
We can do without it.
I just don’t see the point of awnings.
Weatherproof tarp would be great.
Slide through the channel, 4 ground pegs. Done.
Roll up and store with the chairs when not in use.
Yep, or easier still use awning rail thumb screws (like welshgas suggests) and simply tie or bungee on. It depends on whether you want the whole thing completely connected all along. The rail strip will make it bulkier/more cumbersome to store. Also your tarp is more flexible and conducive to different configurations without the strip attached.I just had a quick look. I guess it would be possible to sew in the rail strip and that would work.
I think that was a Brandrup one. Guess they have them in the shop.Cali kev had one at the slimbridge meet. Might be worth asking him where he got it. I'm sure there's a video knocking about somewhere
We use a cheap tarp with a Kador strip, we just use tarp clips to hold the tarp to the strip, instead of sewing it in, mainly because I can’t sew...but also because it then packs away much smaller and can use the tarp in so many other waysI just had a quick look. I guess it would be possible to sew in the rail strip and that would work.
I like the Toyota van, what happened to it?This first setup was on our old Toyota and kept us dry at the wettest festival I’ve ever been too (so bad one of the marquees collapsed under the weight of the rain). The tarp gave us a dry path from the windout awning and driveaway “tunnel” through to the back of the van.
The second was me just tinkering at Easter (Chester food festival) with the Cali. A tarp folded in half and connected to thumbscrews at the ends of each back rail. Poles and guylines to hold it out/up. Worked as a good sun screen without having to put the back blind down. I’ve yet to test it with water to see if water pools by the back canvas of the pop up. Had an idea late and put it up in the dark (that’s why it’s a nighttime photo).
You can also use a tarp as a wind deflector or camp space extender. View attachment 46063
Of course they don’t need to be attached to the van either, a great way for kids to experiment and make a den.
Not everyone’s cup of tea, but I do like to problem solve and tinker! AND OMG, I just love a tarp
Saw one: Expensive from Caliboard.de. It‘s called „Calisail“.
Pros: Add to both awning and passengerside/driversside (down here) rail.
shop.vwcamper.de
Sweet Jesus Sapto.
It’s €169...
Calisail Sonnensegel
!!! Achtung Lieferzeit bei Farbe BLAU zuzüglich 4 Wochen !!! Sonnensegel aus AIRTEX® classic 195g/m²…shop.vwcamper.de
It was fabulous and lasted us 11 yrs from second hand. Very sadly it started to become a bit unreliable (and it was our second “car”). Then it had a very bad MOT fail that included major corrosion underneath. Even if we’d had it all sorted we weren’t able to fit safe child seats for the grandkids, So time to say goodbye. Me & my hubby are pretty tough but it was like losing an old friend and we both shed a tear.I like the Toyota van, what happened to it?
