Fridge
Has anyone managed to make ice in their Cali fridge?
If you use those Plastic Bags for ice cubes and hang it against the back wall with the fridge on Maximum, you'll get ice.
I just put the Gin and Peroni against the back wall.
We have just returned from 3 weeks in Spain and if the fridge is let on MAX it will freeze 2 litre bottles solid that are on the nearest the outside wall. It will also keep meat frozen on the bottom but again mainly towards the outside. Outside meaning the side nearest the side of the van. The other 3 walls tend not to be quite as dramatically cold.
That is because the cooling element is behind the outside wall. The other walls are just for insulation. They have no cooling function other than keeping the cold inside.
F
6K
Auberg-ine
Auberg-ine
dannosail
jts46
jts46
Spuktoid
lewisnoble
L
Customvandesign
