Corrugated windscreen washer pipe
jts46
jts46
Derbyshire & Lot et Garonne
T5 SE 130
Anybody know where i can buy this from, just rang my local unhelpful dealer he wants £20 + vat for a 10 metre roll. I only require 1 metre at most
Ebay?
I´ve got a piece of this knocking about
but you would have to make a big hole in the bonnet for it
and you'd need a bigger water tank and probably have to upgrade the pump,
the advantage would be that it would not only wash the screen but also wash
the van :D
What happened to yours
Are you sure that its corrugated all the way and that the corrugated tube is not
what the pipe is fed through around the bends.
I think you will always have to buy more than is needed, a search online shows
10€
I had this problem several monthe ago.
I cut out the 1/8" that had worn through and through which the screen wash was pouring.
I found on the internet small joining plastic bits about 1/2" long which could be pushed into the two cut ends of the corrugated pipe. It was one hell of a fiddle and took me about half an hour and sprained fingers.
It cost pennies and has worked just fine.
It'll come apart one day but I have a spare
I think I googled something like "vw california worn screen wash pipe"
Here it is
