jts46
Thank you. What size allen key please as i have tried various sizes?My website is in Dutch, but there are pictures of me removing these clips with an allen key here.
that isa good kit to have, i think i will stick that on my christmas list.I find they round off very easily but can be popped out with a forked trim removal tool like this one and just pushed back in. I got a whole set of the tools for about £10 from amazon.
When prising out you need to get in between the 2 bits of plastic and not try to remove the whole thing at once.
I have these holding the fairing and other bits on my motorbike - allen key and they pop out. They can be reused by popping them back in.I need to remove zipped pocket to gain access to inner tailgate.
Does anyone know how to remove the plastic rivets?
What tool do i need?
Part number of replacements?
See attached photos.
View attachment 53052View attachment 53053
What was the part number of the 90' plastic insert? Any pics of this area and the broken insert?Bit of an update, plastic poppers/rivets removed.
Torx/crv metal screws not loosening as the pressed fit nut is turning, am taking it to my local garage to have them removed hopefully, it is a b****** of a job.
Also found the reason for leak from offside front drain hole, the 90' plastic insert had broken have ordered a new one form vw dealer
Thanks for the photos. AutoGlym Interior Shampoo works great on water stains.only pieces left were the two ends in tubing, had to remove part of head lining to gain access, any idea how to clean water stains from lining?
the connector minus the tubing in the ektra picture is what i have ordered.
The other photo is were the connector fits, between brown pipe and black pipeView attachment 53187View attachment 53188
Good job. Like the cable ties, shame VW never fit them as standard.View attachment 53204
New part fitted, now drying roof lining using fan heater and dehumidifier
They did fit them, by the way the 90’ plastic is 8mm diameterGood job. Like the cable ties, shame VW never fit them as standard.
Age?, heat? I don’t really know sorryHow does one of those plastic angle pieces get knackered
Thats a bugger.Age?, heat? I don’t really know sorry
