We have one of these as well, and it's great - practical and neat - perfect. Spices/ salt/ pepper in the lower one, and torches, packs of cards in the top one - all easy to get to. It's quite expensive but worth it.We have always found the one from Brandrup very good. The pockets are flexible so they take assorted sizes of spices, etc. The tops are a Velcro fixing and hold the contents very securely with no rattling. The whole assembly fits to the window with double sided Velcro tape so can be easily removed. We never opened the 'curtain' anyway so didn't miss the extra light and nothing has ever fallen out of them. They are available in the shop with the VIP discount. Called Brandrup Utility for the small kitchen window under Storage Solutions.
When we got the new van with the spice rack fitted. I took the Brandrup out and put it in the boot under the cupboard door in the wasted space.We have always found the one from Brandrup very good. The pockets are flexible so they take assorted sizes of spices, etc. The tops are a Velcro fixing and hold the contents very securely with no rattling. The whole assembly fits to the window with double sided Velcro tape so can be easily removed. We never opened the 'curtain' anyway so didn't miss the extra light and nothing has ever fallen out of them. They are available in the shop with the VIP discount. Called Brandrup Utility for the small kitchen window under Storage Solutions.
Club shop sell the VW Gen ones to retro fit.Hmmmmm.....think will try a crash mat underneath for a while
Wow! what a brilliant ideaA little late to the party here, but here's ours after some tweaking...
Love that!!A little late to the party here, but here's ours after some tweaking...
No, but we only got the van a couple of days before lockdown so it's not been a problem yet!Can you block the holes for sleeping...?
How did you do that ??No, but we only got the van a couple of days before lockdown so it's not been a problem yet!![]()
The panels are frosted so no-one can see in, and I'm just hoping that it won't be too bright in the morning.
If you can work with better tolerances than me then it might be possible to just swap the discs out each evening, but my practical skills don't extend that far.
Standard utility blind from the club shop, and an 80mm drill bit. Then some 80mm perspex discs, and a friction fit into the holes. If the holes are marginally too large then some careful application of superglue around the outside of the disc, left to dry, is enough to then make the friction fit again. I would advise against trying to glue them into place, because it's a bit fiddly, and any overspill of glue is very obvious on the discs.How did you do that ??
I love this! Thanks for sharingA little late to the party here, but here's ours after some tweaking...
Thanks, what about the plants, presume they are fakeStandard utility blind from the club shop, and an 80mm drill bit. Then some 80mm perspex discs, and a friction fit into the holes. If the holes are marginally too large then some careful application of superglue around the outside of the disc, left to dry, is enough to then make the friction fit again. I would advise against trying to glue them into place, because it's a bit fiddly, and any overspill of glue is very obvious on the discs.
I also applied black sticky tape to the back of the blind, purely for cosmetic reasons when viewing the van from the outside.
How dare you!Thanks, what about the plants, presume they are fake
These containers is exactly what I'm looking for. Can you please advice what's their name and where did you buy them? What's their size? Thanks!
