I meant 7 or 8You said 6 thingsallow me?
6. Vacuum in the tank, open cap (this assumes you can hear the pump but no water comes out of the tap)
Thank you very much for the recommendation. Probably a bit too much of a schlepp from Tenterden but good to know as a back up.These guys are good for motorhome repairs, been around for years; Based in Peacehaven (just West of Newhaven):
Edit - might be too far for you.
Used Motorhomes Brighton East Sussex Used Motorhomes Brighton East Sussex | Stewart Mouland Motorcaravans
Stewart Mouland Motorcaravans, Used Motorhome Dealer based in Brighton, supplying Used Motorhomes for sale within East Sussex, including Swift, Auto-trail, Bailey, Elddis, Auto-sleeperswww.stewartmouland.co.uk
Many thanks for such a comprehensive answer. I was going to get someone to do it but with your guidance may have a go myself. Cheers. ElaineIf the water pump isn't working it can be one of 6 things
1. Pump needs replacing - easy job- costs about 15 quid to buy one.
2. Tap micro switch - easyish if you're a watchmaker- costs pence.
3. New tap - straight replacement - easy - costs up to 30 quid.
4. A fuse - easy to replace once you find it but the fuse has blown for a reason.
5. There's no water in the tank.
So whatever it is, its quite an easy thing to sort out and it won't cost the earth.![]()
ThanksDoesn’t the pump work at all? If not it may be just a fuse...
Thanks Pete. That's where I will start. I have a few other little jobs so I do still need to find a good reliable repair shop closer to me in Tenterden Kent at some stage.Doesn’t the pump work at all? If not it may be just a fuse...
Thanks Loz. loads of options. Hurrah. Cheers. Will let you all know if we still need 7 or 8 after the weekend!!!I meant 7 or 8to leave room for some additions.
No problem, Debbie.Thanks Loz. loads of options. Hurrah. Cheers. Will let you all know if we still need 7 or 8 after the weekend!!!
