Ocean Spirit
Eating Ice Cream, skimming stones.
Having never had any problems with my batteries in the first 3 years and not having any electrical knowledge to speak of let alone auto electrics I'm rather in the dark about these things.
I have used the batteries in an off grid way only a couple of times for single nights where they have basically supported the lights and the fridge. I can't recall ever using the heater off grid over night but it is regularly used to warm the vehicle before work for about 20 mins when things are frosty or icy outside.
I glance at the display console almost habitually each time the vehicle has been stood over night or during working hours and while I obviously can't recall the details nothing has ever given cause for concern.
Other than that I charge them from the mains every month or so for 24 hours + and the vehicle gets 44 + miles a day at least 3 times a week on a variation of conditions that includes A roads and motorways.
In the last month I'm more regularly seeing battery capacity down over night and battery voltage also down.
Other than the possibility of the natural ageing process starting to show the only other factors of change are:
Then after a 22 mile commute something like 12.7V and the -0.2 then 0.00 when all the courtesy lights go off. So a full recovery according to the console display. Getting back in the van after work some hours later and the same readings.
So at this point I wasn't overly concerned, then on a day soon after, I got this after 25 mins of heater on level 7 to clear ice
The same commute followed and again full recovery according to the display on arrival at work and some hours later.
Vehicle then sat for 24 hours no issue showing, no draw on the batteries.
Then after another overnight stand stand this
I then set about investigating the Cube fuse as It was suggested by some helpful forum members (on another thread that I joined in on) that if it was blown I'd be using just the first Leisure battery under the seat.
To do that I gave my self a crash course in using a multimeter that I own and that was simple enough, only to find I had good continuity reducing the reading from 1 to 0.00 when connected between the lead to the cube fuse and the battery terminal itself.
But I have to say that I would have struggled to even get the red cap off the terminal nut and remove the battery in such a tight enclosure let alone remove the battery. The compartment has a lip in front, the leads rest on top of the battery and are sandwiched between the battery and a unit fixed above it.
So any tips regarding the sequence are welcome should I need to change the battery at some point?
I mean do you just struggle to pull out the battery or prise off that red cap and push the leads out of the way first?
After about an hour or so with van doors open so courtesy lights on it read this
- I had the under sink light 'random flashing' fixed under warranty
- There was a single bolt of lighting directly over my location that knocked out my next door neighbours computer, tripped my hot tub and set off numerous car alarms (which may have been from the resultant blast that you feel when the thunder is heard)
So blown cube fuse possibility is now eliminated.
