aux heater in 6.1
marek
london
T6.1 Ocean 150
Hi how long on the middle setting will the heater stay on continuous please?
Your Avatar information says you have a T6.
Anyway, unless they have changed things drastically on the T6.1 I would presume “ Continuous “ means continuous.. in that the heater stays On but will go into Standby Mode when the temperature selected, or Level , is reached and fire up again when the temperature drops below the selected level. The heater starts on high output and as the internal temperature rises will back off to minimum. If minimum is too high then when the internal temperature reaches the set level the heater goes into standby mode.
If the set temperature is Low then the heater might be going into and out of Standby. If the set temperature is higher then it might continue on minimal output. It all depends on the difference between set temperature/level and the outside temperature.
thank you for reply. for instance, would it stay on all night?
My longest was 6 days, just varying the temperature. I was on EHU.
