Leisure Battery Replacement - Enduroline
G
Gasf
Just about to change the leisure batteries on my 2013 Cal. Can’t get the Varta LA80 but can get the Enduroline EXV88AGM from Tanya for £139 Minus discount. Anyone got them and are they as good as the Vartas? Size and spec look the same. Thanks.
Thanks - yes - bit more expensive and I would bet 10% CC discount from Tayna. If just the same or similar would probably go for Enduroline.
I used Tanya for a new Varta LA80 (great service). However, I recently bought a new engine battery (Yuasa) and it was cheaper from partsformachines.com. Yuasa must surely do an equivalent spec. Great service also.
Thanks - anybody fitted an Enduroline leisure battery instead of a Varta LA80?
As long as the measurements are the same there should be no issue.
They both seem the same and are both AGM.
  • Width:315
  • Length:175
  • Height:190
The enduroline seems to be leisure instead of dual purpose so may even perform slightly better?
Tayna now showing stock on the LA80.
Thanks - finally decided on the Varta LA80 now that they are back in stock at Tanya. Fitting today.
Vagophile
V
R
CannellWalker
CannellWalker
