Gas regulator removal
Blob
Hampshire
Hi, I have a 2018 Ocean. Suspect the gas regulator has gone dead as no gas at stove, but gas coming out of bottle. Can’t undo the house connector to the regulator. I tried going anti clockwise and went through 180 degs but just got tighter. Is it clockwise to undo? I know the other side has a reverse thread to the tank valve. Thanks Bob
Once it's off I believe you'll need a new olive for when you reconnect :thumb
@Sad the ‘one-time use’ olive is on the other end of the hose, ie. where the hose connects into the housing.
  • Like
Reactions: Sad
@Sad, You had me worried, but I double checked and no olive, so I had guessed you were thinking about the other end . All sorted now, plus the water pump for the sink which also decided to fail ‍♂️
  • Like
Reactions: Sad
Gazbibelots1860
Gazbibelots1860
Gazbibelots1860
Moakesy
Moakesy
Moakesy
a892374923874
