Ah... glad you asked me that...Plans please!![]()
Yes. I made it to fit on top of the (3 bench) multiflex board, under the mattress. The depth dimension is set to use the full boot depth, when I position the bench seat for travelling in camping mode. For day-tripping, I have the bench back against the full multiflex, hence the table-top will have to stay at home.And where do you store it? In the back?
Thanks. No, the 8mm recess in the underside of the 18mm plywood receives the VW table quite snugly, so it is very stable, once in place. More so after painting, as the painted surface offers more friction than the bare plywood surface.That looks great!
Does it just rest on top of the table or do you have something to keep it in place?
You have even put a list of PPE
Thanks! CHF 284 per item sound fair?Get an Etsy shop setup and get flogging these. They look great, well done
Will this withstand outdoor use? I would throw in a concern over condensation, but wouldn’t want to provoke Mr Hyde!I wonder if an IKEA table can be hacked to sit on top of the picnic table.
Products - Discover Our Full Range Of Furniture And Homeware
Browse our full range of products from dressing tables to complete modern kitchens. Click here to find the right IKEA product for you. Shop online and in store today.www.ikea.com
95cm by 95cm is a perfect size for four, and birch is fairly light.
I was in B&Q just now and had a twang of the 6 and 9mm hardwood ply... pretty stiff... I reckon a layer each of 6mm would be strong enough. As long as you have the inevitable initial cupping/warping of the plywood going upwards when you bond them and fully seal it with paint/varnish.
Yes, it is one of IKEA’s nicer tables. Nearly bought one once, but they were out of stock. At £150, I’d start to consider the CHF285 Califamily table less of a rip-off, as I briefly did, during my lengthy session with the router.Maybe I’d have to bin the external windscreen cover and start using curtains again so the condensation forms on the inside of the windscreen not the new and bigger table top.
I reckon the IKEA table top will be properly sealed to cope with the ravages of family use, and so fine for occasional outdoor use. We have an IKEA within cycling distance so I might pop down there to take a look. All that would be needed is four wooden battens fixed to the underside to hold it in place on the picnic table.
My main concern is justifying £150 for a table I’m going to adapt.
We just keep one of these behind our bench and before our multflex alternative.I wonder if an IKEA table can be hacked to sit on top of the picnic table.
We have one of these too, but I don’t find it robust enough. I use it for cooking mostly. My motivation for extending the VW sliding door table was that it is more stable and just feels more civilised. Particularly important when you consider its users and neighbours:We just keep one of these behind our bench and before our multflex alternative.
FOLDING CAMPING TABLE – 2 TO 4 PEOPLE QUECHUA | Decathlon
Our motivation? To create a folding table that takes up a small space in the boot of a car. It seats up to 4 people.www.decathlon.co.uk
Only 80x60 but at £15 it's a no brainer, surprisingly robust and unmarked 3 years in.
Why not Marine Ply. Waterproof so should be fine in your wet and humid Beach.Maybe I’d have to bin the external windscreen cover and start using curtains again so the condensation forms on the inside of the windscreen not the new and bigger table top.
How stable is the top if someone inadvertently leans on 1 edge?View attachment 80775
The picnic table
Stowage option #1 of the table top.
Stowage option #2 of the table top.
Table top upside down
Table top fitted
Method:-
1. Find a friend who happens to be a kitchen fitter and has a woodworking workshop in his garage.
2. Invite the friend and his children over for a walk and BBQ.
3. After a very happy walk with four children getting muddy and splashing in a woodland stream, return home for the BBQ.
4. Ply friend and his children with sausages, salads and scintillating conversation, and discuss plans for a table top.
5. Give friend and his children a parting gift of six freshly laid eggs.
6. Hey presto! Three days later the table top is delivered.
Cost:-
£24 for a single sheet of 6mm plywood
£2 for a pack of Toulouse sausages
£FREE for half a dozen freshly laid eggs
Notes:-
The table top is made from two pieces of 1.0m x 965mm x 6mm ply.
The maximum width to fit the Beach boot would be 1.25m, but, in practice, 1.22m for a standard size plywood sheet.
The table top is about 2.2 times larger than the original.
That method is certainly what my father-in-law would describe as the ‘right way’. Are you going to paint or varnish? And will you be applying the VW logo with a heated brand, or marquetry for a professional job?View attachment 80775
The picnic table
Table top fitted
Method:-
Cost:-
Notes:-
