@leeb , got VB Air suspension on my T6. I am sure VB Air do one for the Crafter. In addition to better handling and a slightly increased payload, the auto-levelling is great ... and it also keep the VW warranty on the vehicle intact.Hi E&P tell me they can't fit their hydraulic levelling system to the 2020 crafter. Anyone have experience of having fitted any similar system?
Wasn't aware you could use vb air to provide levelling whilst "camped up". Can it cope with decent slopes, uneven ground etc?@leeb , got VB Air suspension on my T6. I am sure VB Air do one for the Crafter. In addition to better handling and a slightly increased payload, the auto-levelling is great ... and it also keep the VW warranty on the vehicle intact.
Never heard about the E&P system, but from what I have seen, that is adding weight, seems to be decreasing ground clearance and of course, the hassle of all that remote and a phone app and various other, in my mind, disjoined systems. Did not look very elegant. May work good, but sorry, no experience.
Can definitely vouch for the VB Air system that @Jester has mentioned above.
Interesting...plus much improved ride I assume. Will investigate further regarding costs/spec for both systems. Thanks for adviceIt has its limits. I would say - about 8-10 inches slope, it can manage very well. Anything more, it may not.
My routine - park up, press the auto-level button and go about doing other task. Within about a minute (or less), it levels the van. Don't have to play around with anything. If not happy with direction start van, adjust direction and press levelling button again. Works well for me.
See if VB or Bilstein works better for you.
@sidepod, for me, the first component that makes for better handling is the thicker ARB that reduces body roll. This combined with the air springs, makes the van more responsive to steering inputs. The air springs are more consistent and hence translate steering inputs more consistently. less body roll and consistent steering inputs = better handling.When you say it improves the handling, can you be more specific?
I assume the dampers are the same?
All that is different is the change from coil springs to air springs?
Is the travel consistent through the stroke? If it’s anything like the comparison between coil and air on mountain bikes then it’s probably 6 of one and half a dozen etc.
Again with bikes, air springs are adjustable using volume spacers to alter the behaviour towards the end of the stroke. Is the van system like this?
Discuss.
The ability of a 3 tonne, top heavy van to handle like a hot hatch and ride like an 80's Jag is surely the aim of all these mods, many on here claim to have reached this nirvana despite Newton's pesky laws of motion, its a miracle.When you say it improves the handling, can you be more specific?
Discuss.
Still not fully understanding exactly what is better. Describing it as better isn’t providing a great deal of info. I don’t mean to be picky here.@sidepod, for me, the first component that makes for better handling is the thicker ARB that reduces body roll. This combined with the air springs, makes the van more responsive to steering inputs. The air springs are more consistent and hence translate steering inputs more consistently. less body roll and consistent steering inputs = better handling.
You do have an option to upgrade to better dampers, but I think, until worn out, the VW ones are OK. The dampers are not variable in this case. Not sure if variable dampers or just better quality ones will make a better difference.
IMO, thicker ARBs + Air is the combination for better handling. Upgraded dampers are on the list, and I am sure that they will improve the handling much more (but it is an expensive proposition).
Another thing I do, and this is due sometime soon is replacing all the suspension bushings after about 3-4 years. Considering this now, and heard that replacing with Poly bushes may also help better the suspension.
If replacing the suspension bushes and you want total control of handling then get the eccentric ones to then have Caster and Camber set.@sidepod, for me, the first component that makes for better handling is the thicker ARB that reduces body roll. This combined with the air springs, makes the van more responsive to steering inputs. The air springs are more consistent and hence translate steering inputs more consistently. less body roll and consistent steering inputs = better handling.
Tyres perhaps?ARB's and damping are the most important factors in handling.
With you on that @sidepod . Let me try and explain.Still not fully understanding exactly what is better. Describing it as better isn’t providing a great deal of info. I don’t mean to be picky here.
At the end of the day it’s simply an air balloon pumped up to a given pressure that equates to a desired ride height. There are no positive and negative air chambers and no adjustability of the stroke/stiffness.
If the system was genuinely active where all corners were linked and it was hooked up to braking/throttle and other load instrumentation then that would be a big step.
