T7 Spyshots.
The hybrid might make a good off grid camper with that big battery built in under the floor.
Can do up to 31 miles on battery power alone (apparently)! Wow . Based on a MPV platform too… hhmm.
31 miles ! Lol
Bet it’s the same as most other hybrids, you go 100 yards and the engine kicks in.
A bit of life left in the diesel range yet.
Longer elsewhere:
Zellmer told the paper that the phaseout will happen "a little later in the United States and China" and that it will take even longer in Africa and South America "due to the lack of political framework conditions and infrastructure."
Longer elsewhere:
That's more than ten years away. Whilst a relatively short space of time, a lot can happen by then. I'm not convinced that this is the end for the combustion engine. If the drive to replace combustion engines with fully electric technology wasn't without it's own issues, I'd feel more confident.
I can see why most of the publicity shots are of the two-tone. In one colour it looks a bit of a mess. Although I can't get the configurator to work, so that spoils the fun!
EDIT: Got it to work, not sure I should have bothered! :D
I can think of only one thing with less curb appeal than that! You can be fined for not clearing it up as well.
Anyone noticed the maximum allowed weight: ranges between 2600 and 2850kg for the petrol versions, and 2750kg for hybrid….
With an empty weight of almost 2150kg for the hybrid, there doesn’t seem to be a lot of room for many people and/or california equipments, i believe…
Wow. The side profile on the configurator does look awful! The top of the range doesn’t look much better.
And look where the driver is sitting.
Cabbies favourite ?
I had always thought this was the ugliest thing available, may have to have a rethink.
N
Californication69
Californication69
V
Paul G - 2022 Ocean
Paul G - 2022 Ocean
