Smalls74
Evening all…..
Im the proud owner of a 2012 Cali, 5.1. Monty is his name!
I’ve had the dreaded unsolicited bonging from the control panel, accompanied by the flashing roof open sign too. Roof sometimes only closing in small increments. Fault codes shown as 1000 and V58 (from memory). I reset the control panel clearing the error messages, and the same issues raise their heads, sometimes immediately and other times hours or days later.
Research on this fantastic forum shows it likely to be the roof sensors/wiring loom.
I’ve got some sensors on order and plan on changing them over by splicing into the loom, as excellently detailed by Lambeth Cali. I’ve got everything crossed that this will work.
However, I’ve really lost faith in the electric roof. Even if my fix works I would still prefer a mechanic operating roof. I live in fear of a road trip failure, and the subsequent hassle that would cause, as well as a ridiculously expensive VW repair bill.
I’m considering whether or not to see if I can have a firm convert the roof to a mechanical affair. Peace of mind would certainly be restored. I’ve pretty much zero mechanical ability so it’d have to be outsourced to the an expert.
My concerns are 1) the cost of such an undertaking and 2) the effect on the value of my van.
There are no Calis with manual roof conversions to compare against. If a conversion was to cost £2k, and the subsequent value of my van was to drop by a similar amount then clearly £4k would not be money well spent.
But if the value remained the same then I think I’d happily spend the £2k (I’m plucking that figure completely out of the air!) for the peace of mind it would give me?
Would you steer clear of a Cali with a manual roof conversion?
I‘d be interested to hear your thoughts on the above. And does anyone know of any reputable roof converters in the South (I‘m based in Kent) that I could approach. I appreciate a Google search with throw up plenty but I much prefer to work off of word of mouth.
Thanks in advance for any help/advice you can throw my way.
All the best,
Smalls.
All the best,
Smalls.
