In a word no.We spent the weekend away at a festival. Before we went I bit the bullet and got a portable toilet for the van. It appears to have a bit of a leak in the construction of the waste tank. Has anyone else had this issue?
Quick question - are you only using the blue liquid in the waste tank or are you also putting it in the flushing water? (which you shouldn’t).We spent the weekend away at a festival. Before we went I bit the bullet and got a portable toilet for the van. It appears to have a bit of a leak in the construction of the waste tank. Has anyone else had this issue?
Just in waste tank. I believe this leak has happened whilst I put the fluid in the waste tank whilst it’s stood on its end.In a word no.
If you have put it in the top tank I’m just wondering whether some has spilled out of the filler cap (not an airtight seal) and then tracked along the seam in your photo?
1. YesStrange then, the white lower part is one moulding with no joints or fixings in it - I would have thought that any crack or hole would have a big blue stain round it & be immediately obvious. Its the only place it can be leaking if the water has the Blue in it.
Unless its been used to the point of being over full there won't be any fluid higher than the joint between the grey & white parts.
On ours the only place any fluid can leak out if the shutter is closed, is at the cap on top where you put the clean flush water in as that isn't a water tight seal. Even if yours had been tipped on end with the flush tank full, that should be clean fresh water not blue that leaked.
Can I ask some silly questions? not knowing if you've used one of these before.
1. Is this the first time you've used it - assuming it is:
2. how and where did you put the blue fluid in the tank
3. Where have you stored the free sample of blue fluid (if in the recess on the tank, thinking leaking lid on that)
4. Have you actually split the tank off the bottom of the toilet ( to see if the spout actually has a cap on it)
5. Are you 100% sure the emptying spout has its cap done up tight.
6. how much fluid have you got in the waste tank.
7. when getting it ready for use how much of what fluid have you put where.
I can't explain the overnight leak but would guess its the seam between the white & grey not sealed & its leaked when stood on end as you put the fluids in.1. Yes
2. Stood on end end poured into spout as per Thetford instructions.
3. no free sample came with it.
4. Yes. It’s been emptied twice.
5. Cap is back on firmly.
6. Pre-use - 1.5-2l
7. 1 measure of blue in waste. 1 measure of pink in flush
It’s been checked by wiping it down to clear any existing blue liquid on the outside of the housing and refilling. This picture was the second time it appeared to have happenedHave you confirmed that you have a leak in the waste tank or do you suspect a leak due to the blue staining? If it’s the latter, take off the flushing section and fill the lower section with clean water to test for a leak, having completely dried it first. Not teaching you to suck eggs though.
Hi @be1t0n We don’t stand ours on end when adding the blue (or now green) fluid. We just open the shutter and pour a couple of capfuls in.Just in waste tank. I believe this leak has happened whilst I put the fluid in the waste tank whilst it’s stood on its end.
That’s what we do too… I obviously didn’t read the instructions and didn’t want to stand it on end when putting ‘blue plus water’ in.Hi @be1t0n We don’t stand ours on end when adding the blue (or now green) fluid. We just open the shutter and pour a couple of capfuls in.
Please can you confirm whether you solved the problem. Mine is the same and it’s only been used 4 or 5 times. I’m not having any luck either finding a Thetford Dealer to take it to re warranty support.We spent the weekend away at a festival. Before we went I bit the bullet and got a portable toilet for the van. It appears to have a bit of a leak in the construction of the waste tank. Has anyone else had this issue?
Mine was purchased via Amazon so it went back to them for a replacement. Haven’t actually used the new one yet though.Please can you confirm whether you solved the problem. Mine is the same and it’s only been used 4 or 5 times. I’m not having any luck either finding a Thetford Dealer to take it to re warranty support.
We had a long going issue where a manufacturer refused to honour the warranty ( in the end they offered 5% discount on a new one - item was £300!...so bit of an insult).Hi..I am also having problems with a warranty claim from thetford although slightly different problem in that my red line indicator doesn’t appear when full..I suspect the float (if indeed there is one). Bought from Jackson’s leisure but no local dealer (tried 3) is interested in helping and …[email protected]… is also not interested. Have been trying since 24 August 2021.
I suppose if you ignore problems for long enough then the 3 year warranty becomes invalid.
I too have had difficulty trying to get in touch with a support dealer that can help. The best help I had was that I could buy the seals and do it myself. I’m not sure whether the problem I have is even to do with the seals. Mine too would be a warranty query - in theory!Hi..I am also having problems with a warranty claim from thetford although slightly different problem in that my red line indicator doesn’t appear when full..I suspect the float (if indeed there is one). Bought from Jackson’s leisure but no local dealer (tried 3) is interested in helping and …[email protected]… is also not interested. Have been trying since 24 August 2021.
