only little yellow vested hitlers moan about them connected together. probably all at the CAMC. i've never had anyone complain to me about doing it,but then i don't use CAMCI have a 25m one. A pain to unravel but not that much and as soon as you learn to use the winder, quick to get back in.
I know some like to have a 10 and 15, see post #5 but I read some sites don't allow connections, so just kept with a 25.
They look fine for providing power to a tent, but you would need a further lead to get from the socket end of one of them to the van.
Thats where I keep my engine, no room for a thick 25m cable as well.25m. Store it out the way in the engine bay by the battery compartment.
I have the cable, retro EHU hookup & a couple of adaptors stowed in battery bay.
It works for me, I put the cable reel under the rear of the van and connectThey look fine for providing power to a tent, but you would need a further lead to get from the socket end of one of them to the van.
If used on a Caravan club site expect a lively discussion with a warden & no electricity from that point on......
only the engine temperature is always near melting point!And the bonnet shuts easily!!
The power was 31m awayI had 30m cable. Could reach everywhere, but 90% of times
I'm joking! How did you manage to fit all that ? Would you have a chance to take a picture ?
but the spot was good for getting solar!The power was 31m away![]()
25 metres for me - it’s worked in sites all over Europe - never had a problem reaching the power source. Fits into a zipped nylon bag. Trick is to learn to hold it in one hand and wind up with the other with loops that will fit into bag. If you’re travelling in Europe, you’ll need a continental adaptor plug as well.Hello everyone! I have just bought a 2018 California Ocean. It doesn‘t have a power cable; can anyone suggest what I should be buying? Length etc or are they all standard? Thanks!
What did you do with the engine?I managed to squeeze in around battery compartment
Hook up cable
Jump leads (just in case)
Ground sheet 4m x 4m
Wood block (to put under jack foot on soft/loose ground to spread load)
Door mat
Small Towel
Pack of nitrile gloves if a job is messy
What did you do with the engine?![]()
