subthree
Today I have replaced the engine battery in my 6.1. The reason I am posting this guide is because of the big plastic lump on top of the battery which hinders easy removal of the battery. You need to remove this lump to get the battery out. Here is what I did:
1. Disconnected the negative clamp.
2. Disconnected the positive clamp and also the small black cable on the front right of the terminal.
3. Remove the cover from the "big plastic lump". 2 clips at the back of the cover on either side.
4. Disconnect the 3 red cables. The cables are clearly numbered 2, 3 and 4 - 2 on the left and 4 on the right. These 3 cables are from the rear of the battery. Removing them allows the "big plastic lump" to be moved to the left of the battery out of the way.
5. Lift out old battery - steal the vent plug from the right hand side of the old battery and insert into RHS of new battery.
6. Lift in new battery and reconnect in the reverse order of the above. Remember to grease your terminal posts with Vaseline.
7. Code the battery to the ECU with Carista.
8. Restart your ignition. There will be lots of errors and warning messages. Take the van for a spin to clear them.
VW dealer price £370. Bosch S5A11 AGM battery from Battery Megastore £140. Took me 80 minutes including coding the battery and taking the van for a drive. Happy days.
