That suggests either no 12v power or communication lost. Have you tried resetting it via the control panel in the bench seat flap? Scroll to the error and press and hold the button to reset.Received warning message W255H from Truma and heating does not start. Checked the fuses but no cigar. Anyone else had the same issue with GC600?
Might have to do a hard reset on the boiler itself. Need to remove the bench seat base to get access.Reseting did not do the jop and fuses seems to be ok. VW dealer successed that most probaply the problem might be in fuses, but I have suspicions that it might be faulty control unit
Thanks.. will try that .. is the hard reset in easy to locate from boiler ?Might have to do a hard reset on the boiler itself. Need to remove the bench seat base to get access.
I had to do this shortly after purchasing our new to us GC680…..I had attempted to start the heating, not realising that the gas was turned off…..be warned, there’s a lot of torx screws! But the hard reset worked!Thanks.. will try that .. is the hard reset in easy to locate from boiler ?
