Sourcing new drivers side sliding window unit
DOMINICGG1234
DOMINICGG1234
Chichester
T5 SE 140
Hi all
Looking for recommendations around where I can purchase the above. Been told by VW that the leak and rattling is due to corrosion and a new unit is required. However it’s so pricey with Vw so thinking if I can source online and get auto glass or similar to fit it would make more sense.
Thanks in advance
Hi all
Thanks in advance
Advice given in your previous thread
Additionally try
Ebay
Kernow transporters
hope that helps
It isn't corrosion it's a dreadful design fault that VW have refused to recognise in all of the twenty years that they have been producing that window.
There will be a small section of plastic that has come un-bonded from its partner part. These are part of the drain channel that takes any water that leaks past the window seals from the slide channel to the outside of the van. The exit is behind the glass on the outside so you cannot see it.
There are two of these channels per window, one that you can see at the front of the channel and one that is always obscured in the centre of the channel.
What ever you do DON'T poke anything down the drain hole as that only separates the two plastic parts even more.
I've had three windows changed under warranty in various vans over the years but nothing has ever stopped the leaks happening over time.
Hi all
Thanks in advance
As @rod_vw says, there is a design flaw, so you could end up replacing one leaky window with another….. if you buy a used one make sure it wasn’t replaced because it leaked.
If I knew then what I know now and hadn’t had mine replaced under warranty I would look at a non opening single glass panel
There could be an advantage of buying a used one which is in good condition for a reasonable price. If the aforementioned plastic parts are present but separated. Whilst the window is out of the van it should be possible to clean them up and re-bond them together. The main problem of trying to fix this fault is that it is almost impossible to access the problem whilst the window is in the vehicle.
Hard to believe VW haven’t thought of doing a fix at the factory before fitting!
