Got to say I don’t remember that much coming off when I ran the dashcam wire down it but TBH I could be wrong. I have a vague recollection now after taking the handle off (and breaking it) I ended up just feeding the wire in.I'm sure they come off with the trim, see photo below you can see the blind is still in the plastic removed bit of trim..View attachment 115481
Mine have just been replaced under warranty. 2020 T6.1. Perhaps try a warranty claim first. Blinds are circa £240 each.Is it easy to remove and replace the trim?
I’m asking since my roller blinds are starting to fray badly on the connection between the fabric and fixed piece you pull out.
Does anyone know if you can get replacement rollers for the A pillar?
Thanks!
Thanks! Unfortunately, warranty in Belgium is only 2 years, and I’m approaching 3 years of ownership….Mine have just been replaced under warranty. 2020 T6.1. Perhaps try a warranty claim first. Blinds are circa £240 each.
Sorry no. The dealer didn't give me any paperwork.Thanks! Unfortunately, warranty in Belgium is only 2 years, and I’m approaching 3 years of ownership….
Do you have, by any chance, the part number of the blinds?
The trim is the same for T6 and T6.1 the blind comes off with the trim on both. It is a cali thats shown at about 10 mins onwards on the linked video.I’ve heard that the T6 A pillar removal is a nightmare, the blind comes off whereas the T6.1 is ok the blind stays on
Does anyone have pictures / video / guide of a T6 A Pillar removal?
I’ve been watched the video above but not Cali is there.
Having recently removed the A pillars on a T6 I don’t think they’re the same as a 6.1. On the T6 I think the blinds stay mounted to the A pillar (or they did on mine ) where as on the T6.1 the blind is mounted in the trim.Thanks Andy.
I was told by Jason at @Absolut5 Audio ltd that the T6 & T6.1 a pillars are different.
Specifically that the T6.1 A pillar removal is easy but the T6 is tricky and it’s easy to break stuff.
I also heard this from a different source.
I’d be happy if they are the same as i may need to remove my T6 A pillar!
Hi,Thanks.
Any tips on how to remove the T6 ones?
Did you manage to remove them fully?
Any online guides / photos would be super helpful if you have time
Something like below. I got the hilka trim set from screwfix but loads of options on amazon etc.
A bit fiddly feeding the blind back through but other than that it was pretty straightforward.Thanks for your help, much appreciated.
How was it to put them back in after?
