V
Vagophile
sems to be that...Found in the starter battery compartment (after 3 years of ownership). Part number 7E0 915 4356 BView attachment 117822
Thanks. Yes it does. If it's fine tomorrow I'll have a look.hope this helps.
Shad - a question on LazerLamps. You have a high spec T6 from what I can tell (204). Do you have OEM LED headlights? do the LazerLamps make much of an additional improvement, or do they get lost in the uberness of the OEM ones?Having just completed wiring in a pair of Lazer lamps I had to remove that part to enable cables to be fed through to the battery Area.
On the left of the battery there is an upright shield made up of two or three plastic like plates which connect buy sliding in groves of each other.
Attached on the end nearest the rads and lights is your part at right angles which seems to close off the area to stop any weather/crap coming into the area behind the lights.
if you are still unsure I will try and take a picture over the weekend.
hope this helps.
I can answer that. I have a T6 with factory LED's (very good) and the Lazer Lamps. The Lazer Lamps are fantastic and make a huge difference both in reach and coverage. I have the clip on amber lens covers too which is great in fog/rain/snow.Shad - a question on LazerLamps. You have a high spec T6 from what I can tell (204). Do you have OEM LED headlights? do the LazerLamps make much of an additional improvement, or do they get lost in the uberness of the OEM ones?
You need to be a VIP member to edit posts.*seems... I can't edit.
VOLKSWAGEN TRANSPORTER T5 Battery Side Cover 7E0915435B9B9 NEW GENUINE | eBay
Find many great new & used options and get the best deals for VOLKSWAGEN TRANSPORTER T5 Battery Side Cover 7E0915435B9B9 NEW GENUINE at the best online prices at eBay! Free shipping for many products!www.ebay.com
Hi, I hope you have managed to discover its location. I have a T6 but I don’t think there would be much difference.Thanks. Yes it does. If it's fine tomorrow I'll have a look.
Yes. See attached photo. It fits down the front of the compartment as shown in the parts location diagram in @aeicalifornia's post so not quite like yours: interesting to see that VW have been able to use the same part. Thanks to everyone who responded.Hi, I hope you have managed to discover its location.
