RockinNRollin
Where to next?
So the next challenge is where on earth is the engine code? Nothing pops up in the app!
Mine is on a big sticker on the first inside page of the VW manual, elsewhere in the index it will lead you to a page with the various codes (I’d have a look for you but my van is quite a way down my friends drive and it’s pi$$ing down right now). Once you have selected the code on the settings in the app you should be good to goSo the next challenge is where on earth is the engine code? Nothing pops up in the app!
CarPlay is just a screen of numbers, unless I have missed something.Thanks for the replies. Eventually the app did yield the engine code DNAA (23 plate 150). No sticker in the manual anywhere to confirm this nor in the footwell that I could see. DPF software did work although want to spend more than 30 seconds next time exploring what it can do - suggested 62% which is “normal” apparently. Interesting it says last regen was over 80 miles ago, but the last 20 the van did were on an empty motorway - maybe it just felt it didn’t need to do anything?
The car play worked but I just got a screen of number readouts, not a visual graphic, but again probably a setting somewhere.
Yes it is either constantly update data or you have the option to manually refresh.Does anyone know what the little "infinity" symbol does on the app at the top right?
I was thinking the same as your final sentence. The problem with these type of Apps is you can ‘overthink’ things and sometimes worry about data when there’s no need (possibly?).So then… the last two regens since having the app have been at 190 and 250 mile intervals…….. the DPF gets to about 121% before the process starts (why not 100% ?) and the before and after soot values are around 30% and 8%
I am finding the app useful (because I like to know stuff) but in practice it only really shows what is going on anyway.
I have a 2007 2.5 TDI SE. Do you know whether this engine has a DPF fitted, or not? New to Cali mechanics.With the journeys that I make the TSI will suit me fine, and I won't have to worry about Adblue faults or a replacement DPF . Use it or lose it is a good rule of thumb for diesels and less so for petrol plus the saving on ULEZ both in the UK and continent will help.
Probably yes. My 2006 did - BNZ engine.I have a 2007 2.5 TDI SE. Do you know whether this engine has a DPF fitted, or not? New to Cali mechanics.
In that case yes (I think). From what I remember oil change really important along with the grade of oil. I loved that 2.5 though cracking engine. As @WelshGas confirms above!Thanks. The three letter engine code is BPC.
I have just changed the oil as I read somewhere else that the oil must be kept in top condition on this engine. Used “Quantum” with a genuine VW filter. It certainly does have the feel of a great engine and it makes the Cali a joy to drive, even if she is a bit thirsty around town. Like the auto gearbox as well.In that case yes (I think). From what I remember oil change really important along with the grade of oil. I loved that 2.5 though cracking engine. As @WelshGas confirms above!
