Lower front tyre pressure good tip. Any rubber mats, carpet pieces, mesh fencing around to put under the front wheels (depending how 'dug in' they are)? Perhaps a few more photos will generate thoughts ...
What makes you think the Cali has 4Mo?Have you tried engaging the diff lock…..
You should screw in the towing/lashing eye that's supplied in your jack kit that's behind the rear seat.What’s the best place please to attach a rope to in order to be pulled out from behind . Plus any other advice for getting out of muck ….
Thanks Scoobz
That towing eye is for the front.You should screw in the towing/lashing eye that's supplied in your jack kit that's behind the rear seat.
