18ME
We booked on to Lucksall campsite near Hereford last night to try out our new Cali. Most things went to plan but definitely still need to sort the cupboards despite buying loads of stuff and boxes from ikea last week.
Couple of questions, is there a knack to closing the shutter to the pop top once the top goes down? It seems so difficult to tuck the fabric out the way in order to close the shutter. Also on the subject of the pop top, it rained through the night and had to close it down wet, so do you put it up once you get home to dry it out?
It was also the first time using a Cadac Safari Chef, which is the high pressure version with the C500 canisters. Reading the instructions it says it should work straight away after screwing the canister on. Ours didn’t, so I unscrewed and tried again but still nothing then tightened it up a bit more and nothing so tried again unscrewing then screwing backup and it did work and gas came out. Just fried off some garlic bread then turned it off by turning it right back down. I left the canister on last night but come this morning and the full canister was completely empty. There‘s no other shut off, just the knob that you turn up or down so should you remove the canister after everytime you use it?
