Sliding Door Problem
RosscoPCole74
RosscoPCole74
Dorset
T6.1 Ocean 150
I have a 2022 Cali Ocean with the soft close sliding door.
Suddenly it has become very difficult to shut the sliding door easily. It appears that the door has dropped a few millimetres when it is open as I have to lift it slightly to make it close smoothly.
Any suggestions what could be wrong?
the rollers shouldn't be worn at that age.chck the door fixings haven't come loose
In addition to the rollers check that the slider arm at the bottom has not come loose. Some in the past have reported the lower arm coming loose
Sent from my Pixel 9 Pro XL using Tapatalk
Problem solved. The two Allen bolts holding the door to the top roller bracket were loose. Tightened up, sorted. Correct sized Allen key in glove box.
