Norfolk Jim
Trying to retire but there's always one last job..
Unless you are a contorsionist (if that's how you spell it) I've found the easiest way to pull rear blind up is from outside. Found it nigh on impossible from inside with seat up......... anyway my question is has anyone come up with a novel way of stopping the light ingress down the side of this blind - it's quite a gap to edge of glass and goodness knows why VW didn't make material wider as it would still fit on roller as narrower at the top.
I don't want to go buying a stick on rear window blind as that's just something extra to pack and stick on still leave gaps. My dealer suggested what about a wide vinyl strip down side of rear window - would have no affect on rear visibilty..................I'm pondering a locla chap I know fitting a matt black strip about 75mm wide on inside and see if that sorts it. Trouble is though blind sits about 25mm or more off glass; it's as if you need a small flap of some description stuck on rear window which blind covers over.
Any bright ideas people?????
