V
veedubz4life001
Hey all,
Been an avid Cali fan for many years with fond memories of growing up with a T2 and hired a few California’s over the years. I’ve spent more hours reading through posts on here than I choose to disclose!!. As so many have said previously – this has to be the most super informative forum for the VW California ever!
Finally we can call ourselves California Owners!!!!! And officially part of the owners club woop woop! Purchased our pre-owned (2021) Beach T6.1 (Aussie Version) a few weeks back, which includes electric roof, 4motion (rear diff) with a three seater bench.
So as advised by so many we took the Cali for a trial run over the weekend with the family and so far no regrets! Kids absolutely loved being in it – to the contrary they wanted to spend more time in the van than outside. Still so much to learn and fine tune about how the Cali can meet our needs, so brace yourselves for many questions although most seem to be answered on the forum.
Soooo, the vehicle is super low mileage (13,000 km) and given the age it appears to have been sitting dormant looking for an owner to give it the love it deserves! There is still a year left on the warranty and I want to make sure I get whatever needs remediating before that ends! So being new to posting messages please tell me if I should post each question in an existing post.
Issues I have noted so far include
I don't have a OBD scanner/VCDS to see if there are any error codes but do you think its worth purchasing/getting scanned and clearing codes, has anyone tried and had success?
any comments would be much appreciated
- Roof canvas seems to be pulling away from the upper fixing as previously mentioned on the forum. Would people recommend me taking it to VW (warranty job) or doing the remedial work myself – I have read on here using small amounts of adhesive and pushing rubber seal back into place is the work around, but would this void the warranty? I cant seem to see any labels in the bellows to tell you what version I have – if anyone can give hints to this that would be much appreciated.
- The left windscreen roller blind does not stay in the open position and keeps popping out of the rear view mirror holder thingy. Again is this common and would you recommend a visit to VW.
- Finally, the camper controller, I am getting the dreaded “Error auxiliary heater” and this is my biggest concern. I’m mindful the vehicle has probably sat for a fair while and the aux heater may not have ever been used given the weather here. Also to note the AGM under the seat has been replaced with a LiFePO4 lithium battery (200A JBD BMS ) with RedArc DC-DC charger. The aux heater issues are, when I select ‘operating mode’ the error message appears and then returns to home screen. When I select ‘settings’ the same happens. When I select ’heat continuously’ (level 10) the yellow symbol appears but then I keep getting “please wait” which keeps coming up but get no fan noise or the clicking noise and definitely no heat.
- Also to note the camper controller readings for the leisure battery are inaccurate (as I expected being lithium) although panel shows 0h, 12.7v/0A (is this way off?), although the image on the camper panel shows full blue bars. (the lithium BMS also shows full battery, 3.19a current and 14.33v).
- Pulled 20a + 5a fuses from under passenger seat for min 30sec – no success
- Pulled 20a + 5a fuses from under passenger seat for min 30sec and took for drive – no success
- Door open to let air in vent and tried above – no success (just to note it has been warm here - tried again today and its 25degrees here) not sure if this is causing an error.
- I haven’t pulled the three fuses under the driver side dash as I don’t want to mess too much with fuses and create more issues.
