USB QC3.0 & PD Extension for the Shoe rack to make use of the inaccessible 12v sockets near the C pillar that is obscured by the seat.
Features on / off switch , bezel to cover screw mounting.
Flying leads tinned and ready to connect
12 x24v
Edit- led voltage read out
Very compact in size, (approximately the width of six USB A plugs) could be face mounted anywhere including behind the front seats in the plastic trim.
Intention is to use a switched cigarette socket type plug (fused), but could be wired directly to LB with a Blade fuse.
I'll update when fitted and working.
Far from professional but had some piece of office carpet lying around. If it works, saves 200€ for a Brandrup carpet… will see if it holds and is comfortable enough.
12 x24v
Looking forward to see how this goes. Do you happen to know the output of the USB C?
Now all bulbs at the front are replaced with LED (the ones not show were already replaced)
Unfortunately, in the UK it is illegal to drive with LED headlight bulbs retrofitted into housings designed for halogen bulbs. Not sure in the Netherlands though.
  • Agree
Reactions: Sad
I guess it’s allowed in The Netherlands as I had done this to another car as well and that passed MOT twice.
