inside sliding table
Asjem65
Asjem65
Lincolnshire
T6.1 Ocean 150
Hi
hoping someone has a solution to this. Having previously used the table numerous times, on a recent trip I couldn't get the sliding table to slide out! Managed to move it about 4 inches then stuck solid! have made sure there's nothing obstructing it. I have tried the bed position up, down, front and back nothing works. ive attached a video to try help show the issue.
2023 T6.1 ocean
  • IMG_0223.mov.zip
Have you got chocks down the side of the bench drawer? I’ve found they can cause the table to stick around that point in the past.
do not pull the underside of the table towards you but push it against the cupboard and hold the unlocking mechanism with you right hand little longer ?
Looking at the video over and over again I can only imagine the table leg hits something ...
can you check the leg is completely flat against the table wile you slide it out ?
