Exceptions to the rule "If you have to force it, you are doing it wrong"
Scarlett
Windlesham, UK
T6.1 Beach camper 150
I've heard the rule that in a California "If you have to force it, you are doing it wrong" a few times now. But is force ever required?
I wondered if anyone had any exceptions to this rule, so that I know when I might actually have to persevere with muscle!
One exception I can think of is the quick lock on the legs of the Thule awning - they are really tough and I always think they are going to snap.
And another partially relevent - attaching my bike rack to my brand new tow ball takes a bit of grunt. But I understand that is because the ball is new and it will ease up in the future.
So let me know. What does require force? And if anyone has any warnings of where they have used force, broken something and learned the hard way, that would be welcome too...
I think you've got it spot on with the two you've mentioned, I cant think of anything else.
When I need to remove my CEE-plug (electricity cable) from the van, I need to press down on the lever but also use quite some force to pull teh cable out.
Interesting. Mine is not too bad, I can pretty much do it one handed, both the lever and the pulling. But I could imagine as things have a bit of use they might stiffen up.
I thought it would loosen through the years but it hasn't. I know people have tried lubricants and what not but its not that bad yet.
Removing Water tank cover to replace water pump. Easy to replace if you can open tank cover which can require some force even with the special tool.
Removing the arms on the front seats when putting on seat covers... required Thor like strength and the splined tool cannot slip!
Up until I recently changed the socket (another thread) mine took a massive force to pull out.
Not anymore, slides on and off with ease.
I'm not sure you can blame the ball for that entirely - maybe a small bit of grease might help, but its usually the rack itself that is to blame.
I cussed mine for ages on my Volvo only to find that the rack had a tiny adjuster that allowed the jaws to open slightly allowing the rack to simply slide on.
DO NOT USE GREASE ON THE TOW BALL/HITCH.
Without the friction lock of hitch and tow ball then the bike rack can swing from side to side and make a real mess of the tailgate etc. The rack won’t fall off , just swing side to side.
It helps when hitching up a tow bar bike rack to have the rack nose down on the tow ball and once the ball is in the hitch socket lower the rack back to horizontal.
I’ve been waiting all night for this reply !
I can go to sleep now ;)
Noooooooo Grease , the Westfalia tow ball is heavily painted and is problematic until the paint has worn off, it's a thing. (Or until the paint on the ball has been taken / worn off)
grease on a tow ball that works on friction No No.
Edit, just seen the response's above, now get to bed
