arcadelt
In our California Beach, we run an EcoFlow Delta 2 Max battery inter-connected to the van via an EcoFlow Alternator Charger, so can run a Breville Bambino Plus espresso machine, and induction cooktop to boot.
Agree - Aeropress Go. Enough for two if you keep adding hot water before pressing.Works a treat! Good size for storage.Hi, does anyone have experience with 12V or 220V coffee machines (filter) in the car? If so, which machine?
I use aeropress, but am addicted to gadgets and buying stuff I dont really need!!Coincedentally I have received my Outin coffeemaker yesterday and have made my first cups of coffee with it this morning. (Not sure if you are looking for filter coffee specifically, if so, it's not).
It's a portable coffee maker on battery (USB-c charging) that heats up water for you (so no need to heat it up seperatelty requiring EHU or gas) and makes coffee either by using grounded beans or Nespresso pods/cups. Tested it today and already love it.
When on EHU we use a normal Nespresso machine. But when 'off-grid' or when driving, we were never able to make Nespresso-coffee. And having to heat up water seperately kind of defeats the purpose.
Now, while off-grid or driving we can just press a button and get a cop of coffee.I'm surprised at how well it works. Max of 4-5 cups percharge but thats no obstacle asyou hardly ever drink more then 2 cups at a time and you can re-charge it againoff teh leisure batteries whiel driving or'off-grid'.https://m.media-+amazon+amazon+amazon+amazon+amazon+amazon.com/images/I/61Ig93ycRIL._AC_SL1500_.jpg
temperature was a worry I had as I to like my coffee hot. I read reviews suggesting it wasn't hot enough but I can't distinguish it from my Nespresso machine at home and steam comes off the cup when it's poured so I honestly cant fault it for temperature.I use aeropress, but am addicted to gadgets and buying stuff I dont really need!!
How big a coffee can it make?.. how long does it take? and is it hot enough (I like my coffee hot!)
Love all this![]()
We tried to get a slightly bigger single shot this weekend using a single pod and c70ml of hot water - it was a bit weak, so we’re going to take our smaller coffee glasses in the van next time (or make 2 whole shots each…). Coffee comes out perfectly hot, as machine can top up your kettle water’s temp if necessary.I use aeropress, but am addicted to gadgets and buying stuff I dont really need!!
Love all this![]()
I second the Taylor’s especially the lava java.Keep it simple. Taylor coffee bags. You only need boiling water and a cup. Saves loads of space and tastes great too.
+1 from me for this. Don't use it much now as I have a large inverter & Nespresso machine in the van but I take this with me in the car and or picnic lunches. Works very well indeed.Coincedentally I have received my Outin coffeemaker yesterday and have made my first cups of coffee with it this morning. (Not sure if you are looking for filter coffee specifically, if so, it's not).
We have the travel version which serves ip a nice coffeeAeropress. No electrics required.
thank youtemperature was a worry I had as I to like my coffee hot. I read reviews suggesting it wasn't hot enough but I can't distinguish it from my Nespresso machine at home and steam comes off the cup when it's poured so I honestly cant fault it for temperature.
The max amount of water it will take for 1 coffee is 80ml. If you use hot water it starts brewing instantly. If you use cold water it takes 200 seconds to heat and make the coffee.
I have the throther on van too for when I fancy a flat whiteI used a Wacaco Nanopresso for ages, (requires pre-boiled water). It’s a manual pump but makes a very impressive shot of espresso.
I tried the handheld frothers, but if you want the milk heated, then you also need a pot, stove, etc. - a lot of work for minimal gain, so I got an electric frother (Lavazza MilkEasy). It’s 550W, so a bit much for the built-in off-grid inverter, but fine for an EcoFlow River, which I have between the seats.
And then earlier this year, Wacaco released a USB-rechargeable automatic version (the Pixapresso) that heats its own water as well as extracts the shot! So this is my setup now:
This is not Campervanning it is Motorhoming.
I could tow thatPerhaps you should all seriously think about your priorities, I recommend that you have all picked the wrong camping vehicle and that this vehicle with a tent would be a far better fit!
I too make coffee this way but my filter cone is one that folds together and I put in directly on the mug. Electric kettle or water from a thermos if it has only been in there a few hours, it stays hot enough. https://www.+amazon+amazon+amazon+a...hvtargid=pla-2281435176898&psc=1&gad_source=1It's not too bad unless you have small ones that could knock it over. We use a kettle not a saucepan. The gas kettle is not as accurate as the electric one.
It's coffee time.
Thankfully, my daughter doesn’t bring her tea set up in the van!You always see on youtube people using gooseneck kettles but never thought of getting one for home. It could work in the van, we drink tea as well, as long as it can boil 1 litre of water. The camping kettle we use is useless at pouring and the whistle has never worked.
I have not tried an Outin but my problem would be getting my frothed milk for my latte. The mess we have at home with our espresso machine wouldn't go down well in the van. So would never go the Bellman route.
I have been looking on the Internet for a gooseneck kettle. I found some clearance stock locally, so thought I would give it a go for the next trip. The spout does look a bit vulnerable though. Will have to ditch the camping kettle and find a safe place for it. Cali cupboard Tetris again!
