Fridge stopped working
Oceanwagen
Oceanwagen
Scotland
T6.1 Ocean 150
Hi, the fridge on my 2024 6.1 Ocean has stopped working. The light is still on but the fridge isn’t cold. I can’t hear any humming noise from the fridge. We had it set at 5 as usual and have tried setting to max setting but still won’t come on. Anyone else had this problem?
are you on electric hook up or running off the lesuire battery?
Update:
Thanks for you reply.
Electric hook up.
Since I posted I switched on the ignition and the fridge came back on!
Your controller may be flaky. I had mine replaced recently as the fridge would turn off randomly even will at least 3/4 charge on the leisure batteries. Happened 3 times over various trips and 2 years.
Thanks for your reply.
Yes, I think that might be an issue as we have noticed the fridge had switched itself off again recently without us touching the controls.
Not ideal, although at least we are aware to check now before food is ruined!
Another thing I noticed was that the settings vs fridge temp has changed with the new controller. A setting of 2 with old unit and I could get liquid to freeze if placed near the back. New controller and I need setting 5 to get 4C. The compressor seems quieter too. Could be coincidence but could also be related to the problem controller.
Definitely setting 5 is what we have set ours, although (when the fridge works) you need to avoid putting beers near the back wall to avoid freezing!
Can I ask, was there a particular reason why you wanted to know if it was EHU or leisure battery?
Thanks again.
If leisure batteries maybe they were low or too low on power
I'm curious why you set the fridge at 5. I set mine at 3 and everything is plenty cold and I like very cold beer.
We had found that when set at 4, water would sometimes pool at the bottom of the fridge?
Mine playing up too. Do I need a dealer visit or is the controller an easy fix?
It seems to be a common problem. We are just monitoring now to see if it continues to happen.
Mentioned several times on chat on this video.
Hi I have a 22 ocean. Once when away had exactly the same thing. As van was 6 months old I rang the dealer he said it’s best to switch fridge off before unhooking. It worked fine when driving. On return hooked back up and was ok. Have not had the issue since.
That’s interesting, thanks for sharing that. Will do that in future and see how it goes.
I did and it was because the batteries were not charged enough. They were 6 years old and didn’t hold enough voltage. New batteries cold fridge
Another very useful thread. I’ve just had exactly the same experience on a trip to the Lake District. Thank goodness for this forum!
The fridge is important to us because we carry medicine for my wife that needs to be kept cold. We always carry a thermometer, but long term we wouldn’t want to have this problem recur regularly.
Well I had my controller replaced because of this issue. Guess what, it recurred once during my recent 2 week trip to Italy and France. Now out of warranty so I'll just have to be more vigilant (I'd covered the fridge icon with electrical tape to prevent it illuminated the interior like Piccadilly Circus at night).
Interestingly (or maybe not) my fridge light remained on. It’s just that the fridge packed up - no hum.
Those observations are quite different to mine. Whenever the fridge turned off the light on the controller would also go off. Happens irrespective of the battery charge state.
jts46
jts46
Richard Hurst
Roger Boeken
Roger Boeken
