Windscreen blind securing pin
V
vanless
Kingussie
T6.1 Ocean 150
Does anyone know if it's possible to buy the little plastic bit that fits in the end of the windscreen roller blind to secure it in the bracket under the rearview mirror? Ours is slightly bent and pops out of the bracket when the blind is closed. The dealer has quoted £299.40 for a new A-pillar trim including the whole blind assembly, which seems like overkill when it's only a little piece of plastic that's needed :oops:.IMG_8801.jpeg
Does anyone know if it's possible to buy the little plastic bit that fits in the end of the windscreen roller blind to secure it in the bracket under the rearview mirror? Ours is slightly bent and pops out of the bracket when the blind is closed. The dealer has quoted £299.40 for a new A-pillar trim including the whole blind assembly, which seems like overkill when it's only a little piece of plastic that's needed :oops:.View attachment 138050
There is a fix for that, which has worked 100% for me on both sides of the blind. I can see that your problem is identical: the top plastic stud end piece needs superglueing back and the problem will then be solved.
I will look up my post and add it to this post.
Here it is (there are several posts following each other):
Post in thread 'Front Blind closure problem'
https://vwcaliforniaclub.com/threads/front-blind-closure-problem.55776/post-722602
glue worked for me too .
I too superglued the end piece in place, which does prevent that part from escaping from the edge of the blind.
However I think - tell me if I am wrong - that the OPs problem is that the pin is bent and so it easily pops out of the hole in the little hinged flap over the mirror.
That is what happened to me and gluing the end in does not prevent the pin popping out.
It’s a rubbish design tbh.
Pin does not bend, I believe it will break before bending. I remember at first I had the same idea but thanks to tip on this forum a small drop-off glue is all you need to remedy this bended looking pin.
Link to 3D print if you know someone with a printer
The pin definitely bends. It may break in time but for now it is bent. Believe me. :headbang
Many thanks.
I have copied the details and just need to find someone with a 3D printer who is willing to print a couple.
Anyone know of one?
See private message
I would be interested to see a close up photo of your bent pin @KevH.
You definitely need to bend the whole top bit back and hold tight whilst the glue sets, but I suspect @Roger Boeken is actually correct: though without a photo I am only speculating.
So, you don’t simply glue the end in, you set it at an angle too.
I am somehow going to have to unset that glued fixing and start again. :headbang
Exactly. It is fiddly (I tried to explain in the post I linked to). But I can close to promise it will cure the problem if you can reverse want you have done cleaning out any glue etc., then re-glue with it set dead vertical. I just held it in place by hand because I could not work out a clamp whilst keeping the blind in situ, but someone cleverer might work out a clamp.
Good luck!
