Detritus
Hi all,
A while back I made an LED awning bar, and the cable plugs into the socket to the right of the rear bench seat. It works really well, but I have to unplug it to close the door, and it prevents me from putting my mosquito net across the door. I was hoping to find a quick / easy way to run a cable to the awning casing that doesn’t require an open door or window!
It could be directly, or by creating an exposed socket somewhere that I could connect the cable into (I’ve used SAE connectors so that I can disconnect the wire from the bar). Any suggestions?
