OBD scanner
I
Ian in Leicester
Leicester
Hi, can anyone recommend an OBD scanner that has worked on their T7 California TDi?
I'm having trouble with one I purchased from Amazon.
Thanks in advance!
I don’t have a T7 but a T5, so I can’t say if it will work but check out mycarly.com.
It’s a yearly subscription and prices depend on how many different vehicles you want to check.
I use(d) it on my T5.2 (2013), my (now sold) Toyota Landcruiser V8 (2008), my (now sold) BMW Z4 (2007) and Porsche 718 Cayman (2022).
Works/worked fine on all of them.
I did read on the Ross Tech (VCDS) website that the new Ford based VW trannys are not supported.
I don’t know if this is similar across other scanners?
Bit early in the T7 life to dicking around with faults?
I'm not actually looking for faults. My tracker/immobilizer seems to be blocking OBD port access even when set to service mode. VW couldn't access it to do the software update so I'm working with Meta Track to resolve the issue but need an OBD scanner so they can troubleshoot the problem.
Thanks I will give that a try but if anyone has actually used an OBD scanner on the T7 it would be great to hear from you.
Carista, the latest version Dongle, works perfectly on my T7 Hybrid Multivan but VW have introduced a new security function which you have to register for via the Carista app that gives you a one off security PIN to make alterations of functions.
I thought the latest VAG vehicles were protected by SFD2 which renders all the dongles useless with no prospect of any change.
Even VW dealers can't code the latest vehicles, I believe.
