Printing completed using the carbon fiber filament. I printed numerous sizes of the strainer to see what works best. Will test this weekend once I'm back in the van. My van is a Westfalia Club Joker T6.1 so not (perhaps) the same size as the Cali.
What I'd love to find is a 3D printable exhaust vent ducting attachment for my Ecoflow Wave 2 AC. Yes, I can make one from other materials, but this would be something cool to print. In my case though it would be different from a Cali as I have Dometic S4 windows which angle outwards and I'd love to use one of those as an exhaust. Right now I simply run the tube through one of them and then built a velcro cover which attaches to the headliner to kind of block the outside but isn't perfect.
That would be amazing! There are some concepts available on Etsy (both for purchase or via STL digital downloads) but these are mainly for the front windows like these:Could you post some photos of both the Dometic S4 window and the outlet of the EcoFlow Wave 2 (the latter with some measurements)?
I am not a CAD expert at all but maybe I can work something out if it’s not done already by someone else (although finding that is sometimes a challenge on its own).
My thought is an adaptor that would go from the wider tube to a more narrow/flat piece that then attaches to the window via the locks and is wedged against the frame. Not an easy window to work with, but in fact I had seen a YouTube video of a guy who had done just that but failed to save the link and never found it again. My velcro cover works ok, but the top left has a gap which allows airflow back in. I do have a spare hose which I can send via post...
The reason I use this window is I can sit the Ecoflow on the kitchen countertop and external drainage flows right into the sink. The Ecoflow Wave 2 is just a tad too wide to fit between the seats in a T6.1 so using the front windows is not easy. This is also a problem with the drainage as you'd then need a bucket or something to collect the drainage (in humid environments where the automatic evaporation feature doesn't work properly).
Not exactly. I'm looking for something that would cover the entire window opening with the hose attached inside the van. To only allow the exhaust air out and not have any gaps to the outside otherwise. Again, not an easy solution but these have been made for other windows.Do I understand correctly that something like this Etsy one would come close to what you are looking for?
https://www.etsy.com/nl/listing/1564077582/adapter-fur-mobile-klimaanlagen-fur-dach
I have access to a fablab which has industrial printers. ;-) Can also go CNC or other if needed.Got it but to cover the entire window opening you would need parts that can be connected because there is no consumer printer wide enough to print it in one piece.
Will do, thanks! Didn't mean to pollute the thread, but there might be others with Ecoflow Wave 2 and 3's so might be useful (although for other ideas like the slide windows). I'm not near my van until the weekend... Cheers![mention]Webbah_in_Switzerland [/mention] can you email me at [email protected] so that we can further discuss what you want (to keep the thread without too much clutter)? I would like the dimensions of the window width as well as the diameter of the outgoing hose.
