All batteries replaced and software updated but still losing 10% every 2 days when van is not in use
I also have the PHEV but did not experienced the heater yet. Let me ask 3 questions: is the corner gap below the fridge the only place for the heat to come out? regarding the exhaust coming out I assume this is quite toxic to breathe while sleeping....? while in camping connected to mains... is there also a fuel consumption?
I'm not sure you understand how the Parking Heater, petrol or diesel, works. It is basically a heat exchanger. On one side is the fuel burner that takes air from outside the van and exhausts the combustion gases outside the van. On the other side of the heat exchanger air is sucked in via a vent inside the van, heated and vented back into the van. The 2 streams of air never mix so you won't be breathing exhaust fumes.
The Heater manufacturers state fuel consumption is about 0.3 L/hr on maximum. In normal use about 0.15 L/hr.
Thank you WelshGas!! I pretty much understand now . So I assume that even when connected to mains fuel consumption remains but you omit leisure battery consumption from vent. Am I correct?
All the caming equipment runs from the Leisure Batteries but if on Mains Hookup you are charging the batteries as you use them.
The Parking Heater only uses high amps when starting to heat the glow plug to start the fuel burn. Once running it uses very little.
On my T5.1 ran the Fridge and Parking Heater + lights and charging phone and ipad for 72 hrs off the Leisure Batteries in Knordkapp at -10c. That was on AGM batteries. Voltage was 12.2v at the end.
Thank you Welshgas for your accurate answers!
Hi again
Ok T7 van with with dealer again, 2nd time they had it, its a 2025 T7 ocean and 4 months old, this time they tell me they have replaced all 3 batteries and done the battery update again. I dont drive this an everyday, sometimes will be sat for a week plus, when I got the van home lesuire battery is on 100%, 2 days later lost 10%, guys what lose are you getting when not used, im so confused I thought it would be minimal the dealer tells me there is a drain inline with other calis in store, if you leave your van how much drain over 48 hours, what is draining lesuire batteries when not in use ?
Do you all have to hook up every week to charge when not in use ?
Is there a contact at VW UK?
Thanks Jonathan
Hi All
I have a Septemeber 25 reg Coast tdi. I have had all the issues mentioned and actually only had the van on my drive for a few days whilst it has been diagnosed for 2nd batteries not charging fro engine, batteries discharging to zero in 24 hours and the famous 'please remove charger cable' notification when the cable is not attached.
That said, I now have it back and the dealer had to swap a control unit from showroom van which diagnosed the fault and was deemed fixed.
It is now charging of the engine super fast but the 2nd battery is dropping 10% a day when idle. It is a bit cold at the moment but that does mean that I will be flat in 10 days if I don't start the engine or do EHU. That seems a birt crackers given nothing is left switched on. Is that what I am to expect going forward?
Can someone confirm to me that these new batteries are good to go flat and left for a while without getting damaged like normal batteries when left flat for a long while?
Any comments would be very much appreciated.
Good luck all
Hi All
Good luck all
Hi Ted, after 9 months my leisure batteries do not charge from engine; 7 times in dealer so far...
I got some info from a spanish wassp group who experienced same issue...dealer accepted finally to take the message.... it is the "Disyuntor" (spanish word) translated as "circuit breaker" ; no stock worldwide so just waitting to be fabricated. SO I have some experience of how much it drops when no consumption at all; in 14 days the battery will be 0%; so I should be careful when to EHU
I do not think this is a valid time althogh is slightly better than yours. Anyway I found some info in the T7/ Ocean PHEV manual which goes beyond my expectations; see attached (in spanish though)
Let me ask a question although not in the right thread ...manual says no distilled water to be used in the windscreen deposit....I believe this is the most convenient follwing VW specific solution ...so I mix both 25% VW Solution and 75% distilled water...tapwater will not definately be the right one. Any help what anybody uses?
Hi All
Good luck all
By the way, sure going flat will be very detrimental
Hello,
I had my new T7 Ocean (diesel) in the VW garage for the last 70 days (due to leisure battery drainage - I had them fully discharged after 2 x weeks not using the car).
They tested everything one by one and found out that these are LEDs lamps inside the car that are constantly slowly draining battery (even when not ON). And in around 14 days the leisure battery goes to 0%.
I initialy thought that they found a solution but The dealer contacted with VW just to get information that this is as expected (expected consumption) and the LEDs will drain the battery even when not using the car.....
I do not know what to think about that.
The only question is whether it is normal for the batter to go to 0% from time to time when not using a car for longer that 2 x weeks...
Szymon
Hello,
Szymon
Mine goes flat too after around 2 weeks.
It seems to be normal and I keep it on charge or at least check if it needs to be at regular intervals.
When it drains to 0% does it start draining the first battery? In my case it does.
