Integrating a Power Bank GC600
markab
markab
Suffolk, UK
Grand California 600
I have done a fair bit of reading through the forums on Power Banks and integration, I would like to increase the capability of our 600 by a day or so, I considered solar but it seems to be a bit of a pain on the 600. Really we are never off grid for more than a couple of days. I also contacted a supplier around fitting a LifePO4 and a split charger but the quotes for that are north 3000.
What I intend to do for now is install a victron filax 2 auto change over and integrate it with a DJI power 2000 which has a 3000w inverter. EHU will be connected to the primary on the filax and the power bank 230 output to the secondary of the filax, the load port from the filax will then supply the 230 consumer unit in the GC600. A second feed will be taken from the EHU before the filax and will be connected to the charge port of the power bank. I will add an isolator switch on the supply to GC600 charger and on the Power Bank charge feed.
Under basic operation when on EHU, EHU will supply the Van and charge both the GC battery and the Power Bank charger. When EHU is disconnected the filax will auto switch to the power bank 230 supply, the power bank will not be charged as it was fed from the EHU. I can then decide if I would like the power bank to feed the GC charger or just supply the van.
I think I can achieve this with the Filax a couple of isolation switches, some wago connectors and some flex so the whole thing is pluggable without the need to modify the GC wiring.
Anyone used a filax to achieve this?
Although thinking about this the DJI Power has UPS mode with auto switchover and supplies the 230 output from grid power when connected to the grid. So actually all I need to do is create 2 cables with wago connectors to insert the power bank between the consumer unit and EHU?
possibly put a 16 amp breaker between the EHU and the power bank...
I have a similar quandary…
I have re wired the EHU to the 240v charging input to a EcoFlow power bank. I’ve then put a 13A plug on the EHU wire going to the van system and plugged this into the power Bank 240 V power bank output. This works to a fashion. But there is a problem.
When hooked up to mains power, everything is fine. The mains charge the power bank and the output from the power bank charges the leisure battery in the van. So far so good
But then when you disconnect the main power, then the power pack charges the leisure battery which then powers the van systems. So what you end up with is a battery charging a battery. Obviously this is very inefficient. I get about a 24 hour run of a 4 kWh power pack.
I’m sure there’s got to be a better way. And way that doesn’t involve constantly switching things on and off.
Is there some way you can connect a 240 V output from the power pack to the van electric system so he doesn’t charge the leisure battery but then powers both are 12 and 24 V systems.
To be honest, I have considered just removing or disconnecting the van leisure battery entirely.
If anyone can suggest an alternative, then I’m all for it. But please make it relatively simple. By this, connect it there, job done.
Yes & No. It’s possible and fairly simple to just supply the vans 13A outlets. There are a bank of Wago connections under the consumer unit in the utility cupboard behind the panel. Just unscrew those panels for access. Here is a file that covers how to create a change over panel that gives a bit more detail on those connectors.
I would say using 4kWhr in 24hrs suggests something more than the EHU battery charger loading your power station. The charger as you say charges the leisure battery and also charges the starter battery so I agree its not a particularly efficient use of a power station.
Supplying the 12V without charging the battery is more involved but again possible. I’ve also attached a file that outlines one possible method.
  • ChangeOverSwitch_Simple.pdf
  • USB-C Leisure Battery Support Issue 1.pdf
Thanks for the document very helpful and yes similar to what I was considering.
So in this config I assume that the Power Bank would also be powering the Leisure battery charger? and while not exactly efficient I think along with a full leisure battery should get me 2ish days off grid for those odd occasions I need it.
Any reason not to go with an Auto change over switch something like...
There are two options in the change over switch document. One that powers the entire GC which would include the EHU battery charger. The other that only powers the socket outlets so does not power the EHU charger.
An ATS would work.
An ATS would work.
Thanks!
Do you have the part/model of the din enclosure you used. And can you share the 3d print file, I don't do FB!
Thanks for the help!
I originally did as per Gordon with manual switch but have swap this for an ATS. I will take some pics etc and give bit more info on my current set up if that helps.
Thanks would be great.
Hi sorry fo delay currently travelling. Pics of my setup attached. This is set up using Gordon’s manual switch and 15a instruction but I have swapped out the manual switch for an ATS. This means whenever I plug in ehu it just switches over and if I turn on ac output on EcoFlow it switch to that if no ehu connected. Plus I have used 3phase unit so I have spare contacts I use to run power charging EcoFlow when on ehu. If you need more info let me know I do plan on doing full write up when I get chance.
Hi Folks,
I'm going a slightly different route as I don't require power to the 230v habitation sockets, just an extra day or two from the batteries.
I'm placing a DJI power bank 1000 V2 ( no affiliation, just what I have) in the boot area under the external shower. It should also fit into the cupboards under the bed.
Inputs:
The 230v charging cable is plugged directly into the 230v socket in the boot. When the van is on EHU the power bank fully charges in 1 hour. This makes for convenient charging.
Also a 12v cigarette charger is plugged into the 12v socket in the boot. A voltage sensing relay is used to ensure this only gives an output then it is above 13.6 (i e the van is running). This trickle charges the power station at a maximum of 100W while driving, the fridge uses around 30W/hr... So around 70W into the battery/hr while driving. That's 14.5 hours driving to charge the battery from 0 to 100%. This is obviously not practical so you need to ensure you leave the house with a fully charged power station. This way you should still arrive on site with the battery at 100%.
Output;
For the output I plan to use the 12v on the power station.
I will remove the fridge fuse (15amp, position 2) in the technical cabinet, and place the 12v feed from the power bank into the take off side (lower pin) of the fuse holder at position 2 using an electrical spade. To maintain electrical protection to the fridge I will install an inline 15 amp fuse.
In this manner the power station runs the fridge and only the fridge. My ambient temperatures are not that hot, and I should get 3 days from the fridge. Driving for an hour will add around 2 hours of fridge run time, not brilliant, so you ideally need to plug into HU after 2/3 days.
Now that the AGM battery is liberated from the fridge it will power the lights for a few days (as long as it's not illuminated like a Christmas tree). I have solar, so on good days (without the fridge running) the battery is back to 100% by evening anyway.
If I need 230v (which I never do) I could take it from the power station, nothing that it will drop fridge run time.
The other advantage for me is that we use our camper at sporting venues over long weekends. It's very simple to unplug the two inputs and one output from the power station and bring it into the venue, an hour later it is fully charged and ready for another couple of days if needed.
I intend to put a manual change over switch on the 12v supplying the fridge, so I can swap between the AGM to fridge or the power station to fridge. This just gives me options if the power station is low and the AGM is high, or if the power station has been temporarily removed.
One of the advantages of this is that you are not interfering with any of the original wiring, everything is reversible. You are not discarding the AGM battery, not having to worry about lithium in the engine bay, you have the use of a power station for other applications at home etc. and it's 'relatively' cheap. Power station with car kit costs me €620 euros.
I will report back towards the end of November with pictures and results.
G
Gareth Salton
G
8K
Carryon Cali Camping
markab
markab
markab
