4WDM Pinout & Earth Point – 2016 T6 Ocean 204PS 4Motion
Big B
Big B
Scottish Highlands
T6 Ocean 204 4Motion
Hi all,
I’m trying to confirm the correct pinout and wiring details for the 4WD module (4WDM) on my 2016 VW T6 California Ocean 204PS 4Motion.
I’ve removed the module and checked voltages at the connector, the results were not as I expected, but the wire colours and pin layout don’t seem to match any of the diagrams I’ve found online so far (possibly they’re for a different model rather than the California).
I’m particularly trying to identify:
  • The accurate pinout for the 4WDM connector (power, CAN, earth, etc.)
  • The location of the main earth/ground point for the 4WDM loom, as the wiring loom disappears and is tricky to trace
  • Ideally a schematic or wiring diagram specific to the California 4Motion showing the 4WDM and its related earth points (e.g. Earth Point 68 or similar)
The module is really expensive, so I’d like to be absolutely sure it’s faulty before replacing it—or accidentally damaging a good one during testing.
If anyone has ElsaWin references, wiring diagrams, or photos/notes from similar work, I’d really appreciate the help.
Thanks in advance!
Regards Brian
Hi all,
Thanks in advance!
Regards Brian
Why don’t you register with Erwin and then pay and download all such information for your actual vehicle?
Hi all,
Thanks in advance!
Regards Brian
T8ad
1 Ign Black/Blue
2 Can_low Orange / Black
3 VBatt Red / Brown
4 Can_high Orange / Red
5 Rear Diff Lock Position Switches
6 Rear Diff Lock Position Switches
7 Ground Lower D Post - Brown
8 - Not Used
Thank you for the fast response, I can at least confirm it’s supplies are correct and the earth is good, regards Brian
Can bus is much harder, depending on where the terminating resistors are you could check the resistance, normally you should see 120 ohms but with the can isolating relay it is a pain as you should check with the battery off but the can relay will be off with no power and thus the GWM termination will be out of loop.
Ign Fuse for Diff ECU is SC33, 10 Amp and only feeds this Device (Fusebox below gear shift)
VBatt Feed for Diff ECU is SD1. 20A and again only feeds this device (Fuse Box below gear shift 4th row from left)
See fuse diagrams in VIP section.
Thanks for all of your help, the power on the correct pins and the earth is good, the AWD module is removed and boxed ready for collection. I shall update you once it is tested and or repaired.
Regards Brian
