Chris H
Bit of a list but trying to figure out what options to get on a 204ps dig 4motion ocean. Can't seem to find much info on the list below and was wondering if anyone else knew.
Chris
Chris
- Bluetooth handsfree set with coupling box and WLAN. Mainly the coupling box and WLAN bit.
- Lockable storage compartment. Where does this go.?
- QE6 Storage net ?
- 2E4 17" chassis with 17" brake system. is this needed on a 4motion ocean 204PS ?
- 2MF Heavy-duty anti-roll bars (front and rear) with standard suspension and shock absorbers. Any benefit and is this needed on a 4motion ocean 204PS ?
- II6 With built-in cupboard, type 6. Is this the cold water shower. What do you loose if fitted space wise.?
- IS2 Electrical interface and multi-function control module for external use, Electrical interface for external use (terminal block in driver´s seat, Multi-function control module for external use. Any ideas what they are.?
- Alternator/battery - uprated 180 A/ 450 A (95 Ah). is this needed on a 4motion ocean 204PS ?
- 4HS Rear heated window with window wiper and washer system. Does this effect the STD rear glass or change it.?
- Z2C Laminated glass package in cab. Is this side glass only or front windscreen.?
