Rubber bump stops in the scissor system of a pop-top roof of a T6.1 Ocean
P
Polar
Amsterdam
T6.1 Ocean 204 4 motion
Who can help me with photos or a diagram of the rubber bump stops in the scissor system of a pop-top roof of a T6.1 Ocean? I found the rubber bump stops (rubber bump wills) loose in the drainage gutter and don't know where to put them back?
In the meantime, I found the answer in another message, but thanks anyway.
Thanks WelshGas for sending above diagram this is very usefull for me.
If you just put them back in they will just pull out again when they stick to the mechanism, I put a smear of sikaflex in the recess of the rubber stop before refitting, they are still in position and are stuck fast this should prevent this from happening again.
apart from gluing them back in, I smeared the face of the frame then press onto with silicone grease.
