It looks as if the Victron Energy SmartSolar MPPT Charge Controller 75/15 is not really recommended for anything over 220W input fro the PV panels on a 12V system. So unless you uprate your selection of solar controller, that would probably limit your ability to add a second 170W panel.
Victron Smart Solar 100/15 MPPT Charge Controller with Bluetooth built-in. For 12V & 24V systems in motorhomes, caravans, campervans & boats.
www.12voltplanet.co.uk
I think if sticking with Victron (very good choice IMHO, long guarantees and excellent product support) You'd need to opt for the 100 | 30 to cope with 2 x 170W pannels on a sunny day and still have some headroom.
The general rule is to allow the high voltage cables (PV panels to the Solar controller) to be longer, and try to keep the low voltage (nominal 12V in this case) short if possible as they will be bigger X section for the same wattage / power.
(I've just wired up a domestic sytem on a house in Frace last week where we used 6mm2 to run a 2,5kw "string"of 5 panels in series to a Victron MPPT, where the cable then "jumps" to being 35mm2 between tthe MPPT and the 24V battery, if it had been a 12V system, we would have gone to 70mm2 cables.)
I don't see your link to the solar panel, it gives a 404 not found, but if its max output voltage is more than 50V, then the next bit of advice won't work, you may already know, but if possible, put the panels in series - to give a higher voltage - following the same logic as above.
The Victron MPPT numbering system uses two numbers to define the controller's capacity: the first number is the maximum PV open-circuit voltage, and the second is the maximum charge current. For example, an MPPT 100/30 can handle a maximum PV open-circuit voltage of
100V and a maximum charge current of 30A.
Some peoples' calculations above are based on putting the panels in parallel, fine you could, but you will need thicker cables to the MPPT, in series and I think that 2.5mm would be fine to cope with 340W.
One last consideration for you, I have a Renology 170W panel on my 2007 Cali, it is great for keeping things running while camping, but what it didn't do initially was charge the main battery as well as the leisure batteries. Not many solar controllers are capable of a "twin output" that is required for that, you may not need that, but having a van that sometimes "sits" for long periods, as mine did in the pandemic, I realised having something to keep the imobiliser, tracker and other "always on" circuits ticking over when the van isn't in use is quite useful.
SolarCamper Solutions do seel them....like this one
DIY easy to install Solar panel kits for VW California / Transporter and Mercedes Marco Polo camper vans. Zero drilling or gluing.
www.solarcampersolutions.com
Victron also make a couple, but they don't have the nice bluetooth interfice to see stuff on your smartphone
BlueSolar PWM-LCD&USB Liquid Crystal Display Two 5 Volt USB outputs Lighting control function, fully programmable Three stage battery charging (bulk, absorption, float), fully programmableLoad output with low voltage and manual disconnect (programmable)Load output protected against over load and...
www.victronenergy.com
Hope that helps. Good luck!
Stephen
