Kampa Dometic Easy Awning Pulley
(1 customer review)
£23.99 Inc VAT
In stock
The Kampa Dometic Easy Awning Pulley makes threading your awning onto the caravan a simple, one-person task.
Simply slide the pulley into place, lock it into the caravan beading channel, and attach the carabiner to the eyelet on the awning beading. Then, using Kampa’s unique pulley system, effortlessly slide your awning along the channel to the desired position.
  • The pulley system makes threading your awning onto the caravan a one-person task
  • Large cushioned padding to prevent damage to the caravan
  • Reinforced sewing points
Instructions for use of the Kampa Dometic Easy Awning Pulley
1. Slide the awning stopper and pulley into place in the caravan beading channel. Lock into position.
2. Attach the carabiner hook to the eyelet on the awning beading.
3. With one hand, place the beading into the channel and pull on the spool away from the caravan. You can now slowly walk backwards to pull the awning on to the caravan channel rail.
9120000404
Weight 0.75 kg
Dimensions 12 × 17 × 22 cm
Kampa Dometic
Dometic make the world more mobile. Their motivation is to create products with outstanding design for use in recreational vehicles.
Reviews (1)
1 review for Kampa Dometic Easy Awning Pulley
  1. Michael Bell (verified owner)
    The Awning pulley locks will never fit as the pulley rail on swift will only take 6mm pulley locks. Had to struggle putting my awning on again as this pulley system locks are 8mm wast of time NOT HAPPY
    PS I don’t think this pulley lock will fit any touring van rail
Add a review
£23.99 Inc VAT
98655-770 x 2 1 × £220.00
Subtotal: £7,172.91
View basketCheckout
